Question about Datamax I-4208 Thermal Label Printer
Label printed too long
HI i have a I-4208 and i want to print 2X8.5 '' labels , but the label always has been printed out with lenth of 10.5 inches and 2 inches longer than normal with 2 inches of blank area, i checked every thing and they are fine , page setup, 2X8.5 and picture covered the 99% of the page. but when i change it to 90%, the label lengh is ok and no extra blank area, so could you give me some hints to fix the problem ?
  • 155 Answers
¿Que software de diseño estas utilizando (label matrix, codesoft, bartender) ? Estos programas tienen sus propios drivers, pero cuando utilizas otro driver puede haber conflictos con los tamaños de las etiquetas. Verifica que las dimensiones de la etiqueta en el driver y en el programa sean los mismos y que los margenes sean los correctos. What design software are using (label matrix, Codesoft, bartender)? These programs have their own drivers, but when you use another driver may have conflicts with the size of the labels. Verify that the dimensions of the label on the driver and the program are the same and that the margins are correct.
Posted on Jun 10, 2009
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
Won't print the leading edge of the label
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4208 Thermal Label Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Printer not lining up and display doesn't work
You can adjust the display contrast by pressing and holding the MENU key for 10 to 20 seconds to modify the LCD contrast level.
Jan 17, 2008 | Datamax M-4208 Thermal Label Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
393 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
