Question about Lexmark X204n 4-in-1 Laser Printer
Error 935.12 service mirror motor ini - Lexmark X204n 4-in-1 Laser Printer
Upalim ga radi sve i kad na kraju piseError 935.12 service mirror motor ini ready on izbaci
Posted on Jul 08, 2013
ERROR L1-00
Scanner feed trouble.
The scanner does not complete feeding in the specified time.
Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Use SIM 1-1 to check the mirror reciprocatingoperations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between the mirror motor and the MCU PWB.
Replace the mirror unit.Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home positionsensor.
From the service manual: http://www.scribd.com/doc/74632095/ARM206-M161-SM-GB
Oct 12, 2012 | Sharp AR-M206
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
935 Service Print Error
935 - Mirror Motor unable to reach operating speed.
This error code indicates a problem with the mirror motor in the laser unit, the cable to the engine board cable or engine board itself.
Check the continuity of the mirror motor cable connected to J3 on the engine board.
If incorrect, replace the cable.
The voltage at J3-7 measures approximately +24 V dc.
If incorrect, replace the engine board.
If correct, replace the FRUs in the following order: engine board -> printhead assembly
Or you could try if a power cycle resolves the error (at least temporarily)
Dec 28, 2010 | Lexmark Optra T612n Laser Printer
RICOH SPC430DN error sc202
sc202 is a polygon mirror motor. The most likely problem is that the motor has gone bad, and it will need to be replaced. Occasionally this error is caused by a loose or disconnected cable, but it is usually a bad mirror motor. You should contact your local service technician for replacement of the polygon mirror motor.
Nov 18, 2010 | Ricoh CL4000DN Laser Printer
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
Error SC320 appear on screen..
Polygonal mirror motor error change...
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Polygon mirror motor defective
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
943 service print head error
sounds like a mirror motor error(this is the laser mirror that spins very fast 20k rpms, you hear the sound when its about to print ,sounds like a jet spinning up). In this case you will need a pro to look at it or replace the machine....
Aug 12, 2008 | HP LaserJet 5200tn Printer
Sharp AR-M280U
Hi:
L6-10 will be a polygon mirror motor error, (a multi-sided mirror that rotates in a similar way as a hard drive spins. writes laser data to the drum) .When this code comes up it usually indicates that the motor is locked. You will need a new polygon motor , most techs would change the entire laser unit.
Sorry but It will have to be serviced professionally.
Jan 18, 2008 | Sharp AR-M280U Grayscale Copier
Lexmark X204n 4-in-1 Laser Printer Logo
2,533 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
