Question about GPS
Froze on garmin screen won't give directions - GPS
  • 27,725 Answers
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Posted on Jan 04, 2013
2 Suggested Answers
SOURCE: garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Posted on Oct 25, 2008
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
Screen froze all of a sudden. Unable to turn it
Went to on-line manual and found out how to remove faceplate and reset as advised in response on FixYa. Thanks.
Nov 09, 2009 | Garmin StreetPilot c340 GPS Receiver
Screen froze and it won't turn off
Hmmm. tricky. It'll eventually run flat but connect it to the computer and use Garmin WebUpdater (free download from Garmin) to check the software version - it may reinstall the software.
Nov 03, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
My Garmin C340 froze up. can't shut off and touch screen does not
Have you tried a hard reset? Take off the silver trim ring around the screen by hooking a fingernail under it above the screen and lifting it off. There's a reset button at the side of the screen. Press that for a few seconds and it should re-boot the unit.
Jul 20, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin Nuvi is frozen with a white screen, all I did was take out the memory card and it froze. What can I do?
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
May 14, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 200 frozen screen
Mar 16, 2009 | Sony NV-U71T GPS Receiver
Garmin give wrong directions! (I attempted to
Go to Garmins web site and check for software updates for your GPS I have had about 8 upgrades on my 660 so far. The can fix many unusual problems.
Mar 05, 2009 | Garmin nuvi 200W GPS
Garmin street pilot c330
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
FROZEN SCREEN
By David707,
Since posting ma last re: Screen Freezing on external charge; I did manage to get the system back to some normality by pressing the Reset button located underneath the GPS Antenna flap. However this is likely to delete personally stored data on the system.
I should also state that the same problem occurs when I connect the 610 t my PC via the USB connection (another way to externally charge the battery).
A more satisfactory answer required though.
David707
Dec 28, 2007 | Garmin nuvi 260W GPS Receiver
GPS Logo
87 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
