Question about Philips 60P8341 60" Rear Projection Television
Clear picture i have a magnavox 50" model# rk8550 ak02 and the picture warks and it looks like the red plue and green bulbs work i just cant get them adjustment. on the bulbs i have what looks like a wing nut with a phillips head screw in the center of it. any help would be appreaciated
  • Philips Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    Problem Solver:
HAVE YOU CHANGED THE COOLANT IN THE CRT'S? IF YOU ARE GOING TO DO IT PLEASE DO YOUR HOMEWORK AS YOU CAN RUIN YOUR TV
Posted on Jan 28, 2009
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is too red
sounds like you may have a bulb out, you can pull the screen off to access it but you have to very careful with the screens or you will damage them, only clean with isopropyl alcohol and of good quality, there will be three bulbs in there, red blue green, their location and direction is very important, so dont move them, if they all work clean then put the screens back on, and see if you can adjust the direction from the menu
Jul 03, 2010 | Philips Magnavox 9P6034C 60" Rear...
How to clean guns on Magnavox Rear Projection TV Model 51MP392H
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to tvrepairkits.com and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox Projection Picture Problem
Sounds like you may need the convergence amps changed and also resistors in that area and maybe fuses.
Jan 02, 2008 | Philips 9P5034C 50" Rear Projection...
Blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
