When I type half of the letters or numbers are printing
I have changed the print wheel and ribbon and still have the same problem with half of very faintly printing on all characters.
  • 3,594 Answers
You didn't give a make or model but if it is an IBM wheelwriter press down firmly on both ends of the platen they do work loose.
DickyO
Posted on Jan 04, 2013
  • 3594 Answers
SOURCE: Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Posted on Mar 20, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
  • 3594 Answers
SOURCE: Characters do not print.
The print solenoid plunger has a plastic cap on the end of the plunger it is probably broken. They are available but you need a bit of mechanical ability to install.
DickyO
Posted on Mar 19, 2009
SOURCE: skipping parts of the letters
More likely than not the type needs to be properly aligned. If it's out of alignment, it can result in the top or bottom half of the character typing faintly. Basically, the typebar is hitting the platen too high or too low. When it is properly adjusted (by a qualified repairman), it will type properly.
Posted on Apr 11, 2009
  • 3594 Answers
SOURCE: Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Posted on Apr 30, 2009
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
Jul 08, 2009 | Swintec 7040 Typewriter
When I type it is printing different letters than I am typing.
On most models there is a pitch switch 10.12.15.PS
you need to match the switch to what print wheel is in the typewriter. most common wheels are 10 or 12
move the switch to that area.
if that is not the problem take out the ribbon, corr. tape & print wheel. tuen on the typ. let it home, put the print wheel & ribbon ( Not the corr. tape) turn on let it home tray typing. if works O.K. put in the corr. tape .
Then you are good to go.
Jan 29, 2009 | Office Equipment & Supplies
Simth corona wordsmith typewriter typing charaqcters not letters
turn the power off. Remove the ribbon and print wheel & corr tape. turn the power on close cover let it home. open cover install the print wheel & ribbon try typing. if works reinstall the corr. tape. if not there will be a switch with 10.12.maybe 15 or PS make sher the pitch is in the same number as the print wheel. hope this works. C.W.H.
Jan 22, 2009 | IBM Wheelwriter 30 Typewriter
Diagram to change ribbon cartridge
The cartridge just snaps on, printing half letters may be caused by the ribbon being folded over on itself or not moving look at the ribbon toward a light you should see each letter clearly thru the ribbon
Sep 20, 2008 | Swintec 7040 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
65 people viewed this question
k24674
jasbo
jasbo
