Question about 3M 1720 2500 LUMENS - OVERHEAD PROJECTOR [3M1720]
Broken glass on 3M 1700 version 1720...can i fix it?
Something heavy landed on my projector and the top piece of glass shattered. Can I fix it? Thank you!
2 Suggested Answers
  • 51 Answers
SOURCE: 3M 1700 overhead projector I have a 3M 1700
The button is probably worn out. You will need to get a new button for it.
Posted on Mar 12, 2011
Fan works, light doesn't - replacing lamp doesn't help. Suspect electrical problem. Is it fixable and cost effective?
Diane,
Your bulb socket has probably burned out. As far as being cost effective, that would depend on whether you could find a new socket and how much someone would charge to put it in if you were not wanting to try yourself.
May 21, 2015 | 3M Model 1720 Overhead Projector 1700 BJV
I bought the Living Accents Corona Wicker Bar set the glass top shattered I dont know why but it is a million pieces, can I order another one through living accents
go on line and see if one is available
the glass would have been toughened glass so that there are no sharps to cause injury if broken
glass supply shops ( windows and door manufacturers ) can supply glass cut to size and then toughened
This will save on freight costs to you as you can pick up the new top locally in your vehicle
Apr 30, 2015 | Computers & Internet
Broken glass piece where dlp bulb goes I shattered! help
Please take a digital photo of the broken piece and of the area it came from, Jill, and post that photo here so we can tell what you're talking about.
Aug 11, 2014 | Televison & Video
Assembling 3m 9100 projector
<a href="http://www.projectorsuperstore.com/">Projector SuperStore</a> is your one stop shop for all things presentaiton. Projector SuperStore is your number one resource for Presentation Equipment including Projectors and Projector Accessories from Panasonic, EPSON, Sanyo, Sony, Mitsubishi, InFocus, NEC and more. Visit: <a href="http://www.projectorsuperstore.com/">http://www.projectorsuperstore.com/</a>
Aug 29, 2012 | 3 m 3m 9100 Overhead Projector
I have a 3M 1700 Overhead Projector. After about two months of use, my bulb stopped working, so I replaced it with a new bulb. When I turned on the projector, there was a slight "pop" and the...
Take the lamp out and check for physical damage. Some lamps come defective and can shad (brake glass inside) upon warming up. The "pop" sound could be it.
Feb 12, 2011 | Office Equipment & Supplies
3M S10 projector makes rattling sound and does not light up.
the only moving parts in there are the fans. one of them has a bad bearing and needs to be replaced. it turned off for fear of overheating.
Jul 04, 2009 | 3M S10 Multimedia Projector
Projecter went bang, is it bulb or fuse.
Hello. First, unplug the projector. Next, obtain some paper towels or newspaper and make a suitable work surface on a table. Then, open the lamp door and *being very careful here*, remove the lamp. Immediately check to see if the lamp has indeed blown--usually the bulb portion of the lamp pops into pieces but sometimes it breaks the cone shaped reflector. Next, flip the projector right-side up and shake out any broken glass fragments--hence the need for a disposable surface! Then, using a flashlight, CAREFULLY inspect the area in the lamp compartment where the lamp is aimed at to see whether the heat-absorbing glass or glass filters have been damaged by shrapnel at all. (When a lamp explodes, that much force is generated!) If any glass panels are cracked or pock-marked at all, the projector MUST BE REPAIRED before use. These glass panels can, of themselves, violently shatter due to the extreme heat from the lamp.
If no damage in the compartment has occurred, gently blow out any tiny glass fragments with canned air. Put in a spare lamp and see if the projector will power up--chances are it won't. There is an internal fuse normally located very near the power plug socket. It is usually a Buss glass fuse, 5-7 amps rated, but if you haven't worked on projectors before, I wouldn't suggest removing the top cover to get at it...send the unit off to be repaired...When a lamp blows like that, a lot of times it takes out the power supply section and/or the circuit that powers the lamp (ballast). If glass panels are damaged, the "optical engine" (internal framework that houses all the mirrors, lenses, and filters) must be replaced--that is very expensive--some companies are able to fix the optics without replacing the whole engine. Hope I helped you.---Rick
Apr 29, 2009 | Hitachi Performa CP-RS55 Multimedia...
Glass top broke, can it be fixed
They do sell replacement glass for these, you will have to contact the manufacturer to order or find where to order.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
3M 1720 2500 LUMENS - OVERHEAD PROJECTOR [3M1720] Logo
Top 3M Office Equipment & Supplies Experts
Lampdeng.com
Lampdeng.com
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
