Question about Kitchen Ranges
I have a 911-934190 kenmore the burners works great but the clock,oven is not working at all i have been in it and all the wires are fin can some on give me some help on this pleas thank and where can
Burners works great but the clock,oven is not working
    Sergeant:
  • 475 Answers
Do you know if your range has a fuse in it, or maybe the outlet you have it in.
Posted on Jan 04, 2013
  • 213 Answers
SOURCE: GE XL 44 GAS OVEN
there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
Posted on Nov 26, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore Range
Okay...if the clock assembly appears to be working and the oven light comes on, but nothing else is working, I would double check your input power at the receptacle. You will need to unplug the range and check voltages at L1 to neutral and L2 to neutral. There should be 120VAC on each leg. It sounds like you are missing 120VAC on one side of the receptacle. I believe the clock and oven light will still come on, because they only utilize a portion of the input voltage. The elements, however, require 220VAC. Another way of checking for input voltage is to pull the range out so you can access behind it. Unplug the range and remove the back cover so you can see the terminal board where the power cord is connected. There should be three wires from left to right (BLACK, WHITE, RED). BLACK is L1, RED is L2. There will be 120VAC on each one of these lines when you plug the power back into the receptacle. If you place a meter from L1(BLACK) to NEUTRAL (WHITE), you should have 120VAC. The same is true when you place a meter across L2 (RED) and NEUTRAL (WHITE). If you connect the meter across L1 (BLACK) to L2 (RED) you should have your full 220VAC. If either leg (L1 or L2) is missing, the range elements will not work. If you check in this manner, you not only will be able to confirm whether or not you have proper input power, but you will also be determining whether or not the power cord is good. This may be a simple matter of a loose terminal in the back of the range, or...I have seen where consumers have wired them incorrectly. Check for the following in this order:
1. Double check you breaker to make sure it is not tripped (I know you said you already checked it).
2. Unplug range and check for proper voltage at the receptacle.
3. Remove back cover of range and verify correct wiring of the power cord.
4. With range unplugged, ensure all terminal lugs are properly tightened.
CAUTION: Do not attempt to tighten the terminal lugs with the power cord plugged in. Also, do not attempt to service the receptacle (repair or replace) with the power turned on at the breaker. Votages dangerous to life exists. I hope this information is helpful to you. If you have any questions or concerns, please post back with your comments.
Posted on Jan 31, 2008
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
  • 441 Answers
SOURCE: oven not working Maytag MGR6875ADS
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Posted on Jul 19, 2009
  • 109 Answers
SOURCE: Kenmore Oven - neither the bake or broil work, dial doesn't light
these elements burn out over time so chk. that out
Posted on Aug 23, 2009
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore oven..Burners work on stove, oven doesnt work....
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Oven and burners won't work
First check your breakers, then the wiring from the receptacle to the back of the oven. Check to see if the wires are properly fastened inside the plug itself. Now, in the back of the oven with the back panel off, see it the wires are properly fastened to the connection box. This is probably where your problem is. Re-attach and this should make everything fine. If you wish, you can me at 803 463 5567 and we talk your way through it.
Jan 30, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Nov 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
