Question about Compaq Presario Notebook
I cannot free up disk space on my Presario C disk. I have tried everything that I have been instructed to do. I cannot get rid of "compress old files" Help!
  • 564 Answers
Try the disk cleanup utility if you haven't already.
Posted on Jan 05, 2013
4 Suggested Answers
  • 22 Answers
SOURCE: i need more disk space on presario 1200
perform a disk clean up by right clicking on c disk and then properties and then disk clean.if it still doesnot give u much space type %temp% in run and delete whatever file which is present in it.if u want more space then u can delete ur system restore point by opening my com then clicking view ,my system properties and then system restore tab and then check the box sayinig turn of system restore of all drive and then apply by doing this u can get at leastr 1.5 gb to 2gb of space bu remember by doing this u cannot restore ur com to previous stage through system restore do it if ur pc is problem free.if u want even more space then open my computer and then c drive then document and setting then click the foder by the name of the pc owner and then my recent document and delete all file from there to get this foder first open my com then too and folder option and view and untiock the option by view hdeen file and folder
Posted on Sep 22, 2008
  • 5 Answers
SOURCE: low disk space recovery D
Option 1: Vista itself requiers a large amount of memmory, consider switching to a less demanding operating system like Windows XP, If you prefer the Vista look you can get themes that make Windows XP look like vista (Remember: you will need to backup files which you wish to keep).
Option 2: Insert you vista disk and follow on screen instructions to modify which vista components you want on your computer or use the add/remove windows components wizard on you computer, you may find there are parts of vista you do not require.
Option 3: Continue what you have already started.
Posted on Dec 20, 2008
  • 18 Answers
SOURCE: My D: drive is 99% full how do I free up disk space ?
Music, video and pictures use the most hard drive space. Store them on a disc or on line storage site. After the delete or removing as advised, defrag you hard drive. This should free up space. Get rid of any programs you don't use. As long as you don't delete hidden files you should be fine. Hope this helps. If you are using windows XP go to start, control panel add and remove programs and delete only the programs that you installed and remove only them.
Posted on Jun 21, 2009
I have a Verbatim Clon 500GB external hard drive which only holds 4.65 GB; why??
Windows 7Might not be formatted correctly. Check Disc Management under Administrative tools. This will give the true size including space that has not assigned as a partition.
Aug 28, 2012 | Verbatim Computers & Internet
Tip
How To Clean Up Your Computer
Everything in life needs maintenance, and your computer is no different. Everything you do and see on your computer takes up space. Over time, heavy use can start to weigh it down and make your pc run slow. What can you do when your computer becomes cluttered and slow? That's easy! You can clean it up and reorganize the stored files for optimal performance.<br /> <br /> The first thing to do to clean up your pc is to run "disk cleanup". Disk cleanup is a program that deletes clutter and creates more useable memory. If you are using Windows Xp, you can find disk clean up by clicking on "start", then "programs" and "accessories". Then slide over to "system tools" and click on "disk cleanup".<br /> <br /> After clicking on disk cleanup, your computer will display a message that says it is calculating how much space can be recovered on your "C" drive. When it is finished, you will see a screen that shows choices of files in which to purge on the left and the "ok" button on the bottom. Click on every box that is available and choose ok to begin cleaning your disk.<br /> <br /> This process can take a while, depending on how long it has been since the last time you cleaned your computer. When its finished, the program will have removed all unnecessary files to free more memory space. But we are not done yet! There is still one more program to run the complete the process and leave your computer running at its best. That program is called "disk defragmentor" and its found in the same place as disk cleanup.<br /> <br /> To run disk defragmentor, click on "start", "programs" find "accessories" and then choose "system tools". Click on disk defragmentor and a window will open asking which drive you wish to defragmentate. Choose your "C" drive and then click "ok" or "defrag" at the bottom.<br /> <br /> Disk defragmentor reorganizes files to bring all of your free space to the front of the drive where it is needed most. <br /> <br /> Running both of these programs once every couple of weeks will keep your computer at its best.
on Mar 29, 2011 | Computers & Internet
My d drive says it is 99% free space but it has 4.53 gb how do i get more gb
Your D drive is usually for system restore. Insteed of system restore disk the manufacturer will partition a drive and place the installation data in the D drive. You should have a C drive and this is where you want to focus on. Delete unwanted pictures , music, and other unwanted files. Movies will really use a lot of drive space.
Nov 03, 2010 | Compaq Presario Notebook
Can I increase disk space for Presario F762NR notebook? And if so..how. Thank-you
You can compress the disk and gain a little room which might meet your needs, otherwise you can buy a new disk and install it. I have cloned many laptop disk drives onto new ones. It does take some special cables and and a desktop computer to do however.
Before I do either, I'd try a disk clean up. Turn system restore off then back on to delete all the SR files. Down load CCleaner and run it against the disk and run the registry cleaner.
http://www.piriform.com/ccleaner/download
Disable Hibernation and delete Hiberfil.sys, if the space problem is critical on your System Drive. Its a hidden file on the root directory of your system drive. Open Control Panel. Type Hibernate in the search bar. Select turn Hibernate On / Off.
If you want to try the compress, double click My Computer, right click on the C:\drive, PROPERTIES, check Compress this drive.. This will take awhile so don't turn off the computer or let it shut down. Some say you should not compress the windows folder but I've never had a problem and they slow down is almost not noticable.
Aug 04, 2010 | HP Compaq Presario F762NR Notebook
Will compaq presario v2000 support windows 7
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Nov 04, 2009 | HP Compaq Presario V2000 Notebook
My compaq says the E disc space is full, I've tryed to empty some. I can't. Is there a way to put it on disc C? Also, My windows security seems to have tripled. Can I remove some of those? Thanks
Have you tried to compress old files?
Go to my computer - right click the E: Drive and choose properties.
Hit the Disk Cleanup button - when it appears tick the compress old files option. This can free up a lot of space by compressing files you have not accessed in a long time.
Jul 15, 2009 | Compaq Evo N610C Notebook
Jun 21, 2009 | Compaq Presario Notebook
0 preload disk space
Boot up the laptop then click on My Computer then right click on the C Drive then click on Disk Cleanup. This will get rid of
unnecessary files, deleted files in the Recycle bin etc and free up diskspace. (tick all the boxes to remove the old files).
This process will take a long time (don't stop it) especially if you have not done this before.
Apr 27, 2009 | IBM ThinkPad T42p PC Notebook
Compress old files too large
It doesn't actually delete anything when you select Compress Old Files. It actually searches your hard drive and anything that hasn't been used for so many days (forgot how many). This is ok if you need more hard drive space but if you have enough space, you should not use this tool. It will severly slow down your computer while accessing those files. For information on how to disable this, go :
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310312
If your laptop is slow it probably needs some maintenance like:
Removing Cookies.Temp files. TIF's with CCleaner
Installing ScrubXp to automatically remove such files.
Running Defragmenter in Safe Mode
Also, download and install WinPatrol,Ad-ware 2008 and SpyBlaster.
AVG Anti-virus is great protection against viruses and Trojans
Programs mentioned are free. Defragmenter is part of OS.
MyComputer,C:drive,Tools. defragmenter.
Please remember to rate all users who assist you for free :)
Sep 10, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
