Question about Kenmore Kitchen Ranges
My Kenmore Elctric Range 790.96419408 started to lose power after usage a few days ago. At first the power will come back after a few hours and lose power again after usage. However, the down time becomes longer and longer and finally no power at all. What could be the problem?
ensapp
  • 30 Answers
SOURCE: Philips 42PF5520D
The capacitors in the power supply are probably bad. The best way to check them in circuit it with a ESR Meter. Or you can do what us old technicians call shotgun it and replace all the caps on the power supply module. Let me know it this helps.
Posted on Oct 16, 2008
tborn6
  • 700 Answers
SOURCE: kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Posted on Jan 12, 2009
vkyhunk
  • 156 Answers
SOURCE: you may be a victim of software counterfeiting
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:\Windows\System32.
2.5)
Delete wgatray.exe from c:\Windows\System32\dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINE\SOFTWARE\MICROSOFT\WINDOWSNT\CurrentVersion\Winlogon\Notify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINE ADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEAT THE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START
--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenver your system detects any new WINDOWS UPDATE choose the updates which u want to install... DONT INSTALL WINDOWS XP SERVICE PACK --3.
Posted on May 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
  • 10865 Answers
SOURCE: oven has been cleaning for hours and won't turn off
You will find that the cleaning cycle takes more than 3 hours. Leave it for at least twice that long before you get concerned. When the cleaning is done and the oven is cool it will unlock
Posted on Jun 19, 2009
Getting an F1 code on my kenmore range
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad
Feb 28, 2012 | Kenmore Kitchen Ranges
I have a Kenmore Ceran electric slide in range, model # 629.46799895 ...it was on, started beeping, and showing fault code F1 on the screen
Sorry to read about your problem.
Try this to determine which part is needed.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
I tried to help you.Please help ma and rate/vote this responce. Thanks and good luck
Jan 04, 2011 | Kenmore Kitchen Ranges
We have an F1 error code, and cant get the oven to stay on...it sets for a minute, then beeps a few times, and shows a f1 code again
present.
the ERC (Clock).
repair technician.
panel.
sound).
touch pad.
Dec 05, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Our power went off and we have a gas GE range with Electric Starters. Can you light this range with a match
Yes, you can light the top burners but not the oven while elctric power is not available.
Good Luck !
Feb 11, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven has been cleaning for hours and won't turn off
Jun 19, 2009 | Kenmore 46123 Stainless Steel Electric...
The electronic oven control my whirlpool GS470LEM is blank.
Check the breaker to see if it is tripped turn it off and back on,
Jun 01, 2009 | Whirlpool GS470LEM Gas Kitchen Range
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Kitchen Ranges Logo
26 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
