Question about Garden
Chain saw won't start
My homelite chain saw won't start. If I were to take plug out and put a little of gas in the gas chamber and then put the plug back, if I crank the saw, it will go for a moment or two and then die. try cranking more and it will do nothing
    Sergeant:
  • 137 Answers
Those small carburetors are notorious for being unreliable. Usually the diaphram gets a little split on it and with any hole in the diaphram it can't make a vacuum which is used to pull fuel from the tank into the carburetor.
Hopefully you can find a rebuild kit for the carburetor.
Another easy fix..if you are lucky and the diaphram is fine , is to empty out all the fuel and let the gas tank air out for a few days with no cap on it. Sometimes the fuel pickup line inside the tank gets super soggy and collapses from the slightest suction. Letting it air out will make the rubber tube more rigid and it might work.
Since your saw does work when you pour fuel directly down the carburetor, that defines that the problem is fuel delivery or lack of it.
Posted on Jan 27, 2015
  • Garden Master
  • 14,363 Answers
Are you priming it Salvador?Check the plastic bulb,may be cracked and not putting gas in the chamber.
Posted on Jan 05, 2013
  • 152 Answers
SOURCE: Poulan chain saw. After starting, chain drive won't move
If equipped, the chain brake may be engaged. Its the lever just ahead of the fore handle. (pull back on it)
If the clutch assy. were frozen, then the chain would move all the time.
Good luck
Aduz
Posted on Mar 11, 2009
  • 384 Answers
SOURCE: I have a Homelite model 20 chain saw. It will
on your machine may be on the side of it that led into the carb should have H for high L low L is for the idle H is for all out ball to the wall you will need a small long screw flat head . put in the H ,turn out for more gas in for less good luck
Posted on May 12, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite 240 chain saw will start & run for about 2 min then when
Delete this; no response to clarification since Feb.
Posted on Sep 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Have Homelite 33cc gas 14
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins.
If the saw is new return it for a replacement. An authorized repair facility should at the very least repair it at no cost to you.
http://www.homelite.com/
Under "Contact Us" select "Service Centers"
Posted on Sep 25, 2009
  • 4088 Answers
SOURCE: hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 15, 2010
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
Started homelite 16 in (the jd 3816 model- new plug and started on a small dose of raw gas--got it running but won`t open full thr ottle- this saw has had very little use- oh put in new j-8 plug but once...
Either that season's gas dried in the carburetor affecting it's operation or you are drawing air through a fuel seal somewhere. Both are common with this model. Sometimes will start from cold and run up to half speed until you take the choke off. Then it just dies from not drawing gas. Status proved if it revs up if sprayed with short blip of ether from 7" away at the moment it dies. Do not try to keep it running on ether more than a minute. Like pure gas, it'll burn up the engine or worst. Do not use ether if the air is not moving. Ether may collect and explode.
May 05, 2011 | Homelite ZR10926 16 Chain Saw
Correct mix of gas and oil for Chain Saw
The ratio is 40:1, provided this is a gasoline homelite chainsaw. Find the suitable amount to put into the gas can at a ratio of 3.2 oz per gallon. The bottles that you buy the oil in have marks on them telling you how much there is, and often times, are sized to dump into a preset amount of gas. Put the oil in the can, then put the gas in the can, cap, and shake. Always shake before dispensing.
May 30, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
Will not start - new fuel 50-1 mixture, checked filter- ok, spark plug sparks, cylinder has compression, finger test, 45cc, aprx 5 month old.
Will it start if you pull the plug and spray starting fluid in the chamber? if so then I'll bet you have a blown diaphragm in the carb or a plugged fuel filter or a bad gas line. hope this helps. Jeepfxr
Oct 08, 2009 | Homelite ZR10926 16" Chain Saw
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
May 12, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
