Question about Kitchen Appliances - Others
Thermostat control no longer works.
Where to buy new thermostat control for throw
    Sergeant:
  • 475 Answers
Maybe best buy might have it or maybe do you have a Radio Shack they might have it also.
Posted on Jan 04, 2013
Thermostat not running furnace properly
Assuming that particular thermostat has a common mercury switch, the wiring behind or just inside the unit may be causing a strong enough magnetic field to throw off the balance of the mercury (liquid metal). The same scenario could be caused by other wiring or devices near the thermostat.
To test this theory, hold a compass as near as possible to the thermostat and wait it to come on automatically. If the needle moves when the switch engages, the magnetic field is strong enough the throw the balance off.
When tucking-in the wires for the thermostat, avoid winding the wires in a spiral or wrapping them around anything. An active current through wrapped or winding wires will create an electromagnetic field.
Oct 28, 2012 | Heating & Cooling
Overheating no noticeable signs that radiator is leaking, no fluid around the water pump to indicate that it may be going bad, temp gauge hits 180 then the fan kicks in...do you think the thermostat may be...
I would put money on the thermostat as a first culprit. Water pumps usually fail in a leaking state rather than in a "not pumping water" state. In the current weather, there will be little harm in running without a thermostat to test it (or even longer if you want to). The thermostat is usually in a housing at the end of the top radiator hose. Unbolt the housing, pull the thermostat, make a new housing gasket out of a cereal packet and take a drive out.
If it works, go buy a new thermostat and gasket at your leisure.
Jul 26, 2011 | 2003 Chevrolet Impala
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Nov 29, 2010 | Lakewood 2727 Heater
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
TRD 1230 ER ITS STOPPED WORKING.. ANY IDEAS,
If it has a manual control,not digital,remove the control panel,and remove the thermostat,and use a finger nail file,and file the contacts in the thermostat,the points,contact points.This is about all you can do,if it is anything else,throw it away,and buy a new one,the parts are as high as a new heater.If it is a digital control,throw it away period,cost to much to repair.
Jan 15, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
My power switch broke and need to get a new one. Does onyone know where i could purchase a new thermostate switch or should i throw it away?
If your talking about the thermostat you will have to throw it away. You can buy one at any Lowe's, Lumber Yard or Home Depot.
Jan 02, 2010 | DeLonghi Heating & Cooling
Hotpoint FFA80 Freezer Fan stopped working
This information may help you - it could be the fan motor itself by the way.
Servicing the Thermostat Control
©2006 Publications International, Ltd.
Thermostat controls regulate the temperature of the refrigerator
and freezer. Remove the control panel to reach the controls.
The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary
May 09, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
