Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Child Lock light flashes continuously
The child lock light on our KUDS25SHBL0 dishwasher (S/N FJ0702990) began flashing continuously without our setting the child lock. We tried holding the Energy Saver Dry button down for more than 4 seconds to see if it would stop, but it continued flashing. I removed power for a few seconds, but after connecting the power again the lock light still flashes. The dishwasher will not start. According to the Technical Service Data Sheet for this dishwasher this symptom appears to mean that one or more of the buttons on the console is in a "stuck" state. Do you agree that this is most likely the problem, and is there a diagnostic test I can do to verify that before I order parts. (I do my own repairs.) If it is a stuck button, do I need to replace the console assembly, which in a whirlpool parts list they sent me is shown as P/N 9744112, or the electronic control, P/N 9744031, or both? Also, where can I purchase these parts at a reasonable price? Thank you for any help you can offer me.
  • Allen Currano Jun 27, 2007
    I just looked at the Technical Service Data Sheet again, and found a third possible part that may be the one at fault - the "User Interface" module, P/N 9743995. I am guessing that this is the module that contains the actually switches and lights, but since there is no picture, I can't be sure.
  • Allen Currano Jan 27, 2008
    Thanks, Gendos. I didn't see your comment until now, long after I fixed the dishwasher. You are right - I did have to purchase the entire console assembly due to the bad keypad. I don't recall what I paid, but I think it was about $150.
    Scholar:
  • 76 Answers
Allaroni No doubt the problem with your dish washer is bad key pad due to stuck button(s). The user interface you found in the technical data does not exist and what Whirlpool meant under this name only Whirlpool knows. They do not sell the key pad separate and that?s why you have to buy the complete console. Wherever you found the new part if it cost more then $150, let me know and I can get a better deal for you. Gendos post back....
Posted on Jun 28, 2007
Hold down the Energy Saver Dry button down for more than 4 seconds. This worked for me.
Thank You Very Much allaroni
G. M. W. 1/26/2008
Posted on Jan 27, 2008
The child lock light flash
Hello. Your Kitchenaid unit has the child-lock enabled. Look for a button(or set of buttons) that has a small lock symbol beneath or the word "lock". On most models, you have to push and hold the button(s) until the lock light goes out(usually about 3-5 seconds). That should disable the lock and the unit should operate normally. I hope this helps you!
Dec 18, 2015 | KitchenAid Dishwashers
Our dishwasher continuously flashes "CL"
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jacques
*If you found this solution helpful, please rate it
May 23, 2011 | Dishwashers
No trabaja lo unico que tiene es una luz ensendida -chid lock
Pulse y mantenga pulsado
durante 4 segundos. SEGURO PARA NI?OS brilla.
Si pulsa cualquier tecla, mientras que su lavavajillas est? bloqueado, el
la luz parpadea 3 veces.
Para desactivar el bloqueo para ni?os
Presione y mantenga AHORRO DE ENERG?A EN SECO durante 4 segundos. El
la luz se apaga.
for those of us in English... the child lock is on...
Press and hold
for 4 seconds. CHILD LOCK glows.
If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Sep 02, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Lock on light flashing. Dishwasher will not do
Hi
This is a child lock feature to stop unwanted operation of the buttons. The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function.
Hope this helps. Please do rate this answer. Thanks.
Aug 16, 2009 | Kenmore Dishwashers
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Oct 24, 2008 | Frigidaire 24 in. FDB2321REC Stainless...
Dishwashers Logo
1,210 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
