Question about Alesis DM6 Electronic Drum Set
No sound from bass drum
I was playing and everything sounded fine, and then my bass all of a sudden just went out! Now whenever I hit the bass drum, there is no sound.
    New Friend:
  • 3 Answers
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Posted on Jan 11, 2013
I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
Mar 10, 2014 | Music
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM7 bass drum wont work
the solder on my kik keeps breaking off. you might have sensitivity issues. it can be adjusted on module.
Jan 22, 2012 | Alesis DM7 USB Electronic Drum Kit
Every time i hit the bass drum i hear a click along with the bass drum sound...i cant figure out where it is coming from
Unplug all the other triggers and see if it is in the mechanics of the kick mechanism. If not, then one at a time plug in the other triggers till you find one that is causing it. Could even be the bass when amplified is triggerin lightly the rim of the snare for instance.
Sep 17, 2011 | Roland KD7 Drum Controller
My bass drum stopped working. The module wont pick up any signal and ive tried everything short of replacing it. Not sure if its the wiring the module or the drum sensor itself.. Everything else works just...
Verify the module by connecting a different pad to the bass drum and see if you can trigger the bass drum sound. This would test the module. Now connect the bass to a different input and see if it will trigger that input. SOME of the triggers have a very small potentiometer in them. I have seen vibration break this pot loose rendering the unit inoperative. Also some people have pushed a screwdriver into the pot too hard and broken it off. Once you know it is the bass trigger, open the unit and look for damage. The sensor is usually a piezo disk. These can break away from their attachment. Reattach with contact cement after cleaning the residue.
Apr 14, 2011 | Alesis DM6 Performance Electronic Drumset...
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Apr 05, 2011 | Ludwig Classic Maple Power Drum Set Shell...
Alesis DM6 Electronic Drum Set Logo
127 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
