Question about Yaesu FT-950 Transceiver
Ft-950 not transmitting on SSB
Does not transmit in SSB mode
3 Suggested Answers
WV6Z
  • 7 Answers
SOURCE: FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Posted on Jun 26, 2009
WV6Z
  • 7 Answers
SOURCE: PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
No transmit in ssb
will it transmit in th am mode
Mar 02, 2013 | Uniden Radio Communications
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Icom 7410 won't transmit in SSB works in CW and RTTY
I'd contact Icom, if its under warranty get it fixed
Jan 18, 2012 | Icom Radio Communications
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
Sideband carrier??
im not sure carriers are measured in pounds, but SSB is a supressed carrier mode, in SSB only one sideband is transmitted and the carrier is inserted at the other end in the receiver. In AM mode the carried and both sidebands are transmitted. with regular am there is a carried and when modulation (your voice) is added a signal appears both above and below the carrier frequency at a distance relative to the frequency of your voice. so if you have a carrier at 1000 khz and modulated it with a tone of 100 hertz the signal will contain frequencies of 900,1000, and 1100 hertz, then its changed to SSB by supressing the carrier (1000) and one sideband (1100) if you are on lower sideband and (900) if you one upper sideband, and transmits the remaining frequency.
Nov 06, 2008 | Ranger RCI-2995DX Base Scanner
Yaesu FT-950 Transceiver Logo
29 people viewed this question
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
