Question about Microsoft Xbox 360 Console
Share xbox with pc internet connection
I have an HP pavillion (model 7480) with wireless lan and want to share the internet connection. I also have a netgear wireless router available but not set up. My xbox and internet modem is in basement but computer is upstairs and modem is wired to up stairs but I would like to connect into the basement modem and still share with the upstairs pc (HP). I need help with setting up router (if necessary) and the changes to control panel that are necessary.
  • texlov Jan 19, 2009
    I see nothing that helps me at the referred site
  • Microsoft Master
  • 19,396 Answers
If the Router is a modem router , with phone connection, connect it to the phone socket where the modem is currently plugged in, connect a computer (a laptop?) to the router using an ethernet cable to configure it.
When everything is ready and router is on, call your Internet Service Provider phone number to get step-by-step instructions on how to configure the router for your ISP internet settings.
If the router is not a modem router, connect the modem to the router using an ethernet cable on one of the router's RJ45 connector, then connect the router to a computer.
On the computer put router IP on internet explorer address bar, to open the roputer control panel.
You will be asked for ID and password to access the router.
Once you enter into router configuration, the only settings you need to change are the wireless and security (set a wep key) settings.
Refer to router user manual to find out Router IP, and user and password to access router control panel.
Posted on Jan 21, 2009
    Scholar:
  • 160 Answers
Get a wireless router to make it support instead of wiring connections.this will solve the problem easily
Posted on Jan 19, 2009
  • Microsoft Master
  • 4,806 Answers
Hi there
The only way you can share an internet connection from your laptop is with a "crossover cable" this is a pain as you have to have an ethernet crossover cable attached to the laptop and will have to be at least 30ft long for what you want it for.
I suggest you get your wireless router set up and purchase a Xbox 360 wireless adapter from a company like Amazon for example.
This will cut down the need for very long ethernet cables.
Good luck and thanks for using Fixya
  • Microsoft Master
  • 13,433 Answers
Best choice is to wire the xbox directly to the router, and then if required do port forwarding on the ports that are used by xbox live. Let me know ones you have wired the xbox to the router and we can continue.
  • Ekse Jan 19, 2009
    In your basement, you may need to add a cheap 5 port switch between the modem and the wireing that goes upstairs so you can have the xbox directly connected to the modem via the switch, this way all we need todo is to open the ports on the modem if required and it should work perfectly.
    The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
    • TCP 80
    • UDP 88
    • UDP 3074
    • TCP 3074
    • UDP 53
    • TCP 53
HP Pavillion ze 2000 has no wireless connectivity
Try installing the latest audio and LAN drivers.
You can download the audio, LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 10, 2012 | HP Pavilion ze2000 Notebook
Need lan wireless driver for hp pavillion m8100n for windows xp
Here is the LAN driver but you must have a Wireless PCI card or USB wireless device if you already have one let me know what type you have Make Model and your operating system
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=ca&dlc=en&sw_lang=&product=3440614#N308
Sep 06, 2011 | HP Pavilion M8100N PC Desktop
How do i join and set up xbox live from my laptop to my xbox360 console using a ethernet cable/help
1) Connect your ethernet cable to your computer and xbox
2) On your PC, Go to network connections and right click on your wireless connection
3) Click the advanced tab on top
4) Go to Internet connection sharing and check the box, click OK
5) On your xbox, Go to your network settings
6) Edit settings and set everything to automatic
7) Test Connection
You must have your PC on at all times to connect to Xbox live this way.
If this setup doesnt work.
1) Go to Network connections
2) Select both your wireless connection and your LAN connection
3) Right click and bridge the connections
4) Same setup on Xbox as the previous instructions
5) Test Connection.
Apr 29, 2011 | Microsoft Xbox 360 Console
I have a hp pavillion dv6000 my wifi use to work and now it doesnt. It says that i have to reboot from my dics or go to web site to redownload it. so how do i do this. i dont have internet on it at this...
reinstall the wifi driver from the CD that came bundled with the laptop.
Also you can share internet using crosstalk(LAN) cable.
For more info reply me
Mar 22, 2011 | HP Computers & Internet
I'm REPAIRING A COMPUTER FOR A CUSTOMER, HP G50 VISTA UGHHHHHHHHHH (VISTA. THE PROBLEM IS I CAN'T CONNECT TO THE INTERNET. VIA LAN OR WIRELESS, NOW I CAN MAKE A WIRELESS CONNECTION BUT THERE IS NO INTERNET...
Hi, You need to go into Control Panel, Network and sharing center, there you have all your options, I know it`s different, but more secure, "select Connect to a network" and the rest should be easy.
The thing you have to remember is vista and windows 7 will not connect to an open Wifi, (like a Donkey you will have to drag it and point to it) because it thinks that that connection is not safe, it is all about security.
Hope this helps.
Mar 17, 2010 | HP Pavillion G50-111NR Notebook
I have a IBM netvista desktop and a HP Pavillion on my home office work desk. Now I am getting a message that they are sharing the same IP address! What happen to change one of the Ip address to match the...
Do you use both computers in an existing network (same network)?
Are you using both computers in this same network sharing broadband (internet connection in the same networK?)
Mar 16, 2010 | HP Pavillion s7420n PC Desktop
Cant connect to xbox live with vzaccess!! please help...
You have two options. Number 1, plug the 360 into a LAN port on your PC and set up the LAN connection to share the internet with the VZaccess connection. This will work as long as you are connected through vzacess manager.
Option number two, get an EV-DO router, wireless or wired, and use it to connect the xbox.
If using option 1, you may have to struggle at first with the IP settings. Make sure the LAN connection AND the 360 are set up to configure IP and DNS automatically. And make sure that you set the sharing options to include http and such. more help can be found by searching in Windows Help for ICS (internet connection sharing)
Jan 11, 2009 | Microsoft Xbox 360 Console
Xbox 360 live using internet through my laptop
Normally you would connect your xbox directly to the router. Is there a reason you are trying to connect to your laptop instead? (distance, etc.)
If that is what you truly want to do then first thing make sure you are using a CROSSOVER cable to connect your laptop and xbox together. standard network cables only apply to connecting to routers, switches, and other network controlers. If you are connecting two devices directly you must use this type cable. It is ussally red.
The share tab is only for sharing dialup connections to LAN connections. You are sharinbg two LAN connections so all you need to do is bridge them and make sure there are in the same IP group. Check the status of your wireless card to see what address the router is assigning to it. Then assign the IP to the wired adapter with a differnt higher number.. Example: If your wireless card is 192.168.1.100 then make your wired adapter 192.168.1.151 This should make it work.
Again, it would be much easier to connect your XBOX to the router like it was intended ;)
Jan 03, 2009 | Microsoft Wireless Network Adapter Xbox...
HP Pavillion ze2000 (can not connect to internet)
Make sure you have the internet connection you are trying to connect to is set as your defualt and the reason you are having conflicts with your IP adress is because of how ytour internet is shared.
Oct 22, 2008 | Computers & Internet
Boost signal to allow xbox live
1 buy and cantenna and a hawking hwug1 (from hawking website). install hawking on computer (usb wireless device) and then run the network wizard to make the connection a proxy server. run a lan cable from the computer to the xbox, and enable the wireless connection on the laptop to be shared with other computers on the network.
Sep 25, 2008 | HP Pavilion dv6000z Notebook
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
