Question about Spring Air CS-1 Air Purifier
Can't find manual for my spring air cs-1 purifier. it is dirty inside and need to clean
Model#cs1-11-us-oak
Cleaning inside of system
Call (336) 499-2505 and they will email you cleaning instructions for free. Tell them you were on Fixya.com.
Jul 16, 2012 | Ecoquest Flair Air Purifier
Ionizer wires get dirty
IT'S THE NATURE OF THE BEAST. IF YOU TRY A ANTI STATIC CLEANER THIS MAY HELP .. JAY THE POOL PUMP REPAIR GUY FLORIDA
Feb 03, 2012 | Honeywell Enviracaire Elite F300E-1019 Air...
Is it possible to obtain an owners manual for the Ecoquest Fresh Air-Model Fresh Air 2.0? Intelliair SynAir G? We purchased a used one, biut need manual for proper cleaning instuctions.
The link below is to the EcoQuest Fresh Air manual. It doesn't specify model #'s but should provide you with the information to clean your unit. Thank you for using Fixya!
Greg
Ecoquest Fresh Air Manual
Jan 11, 2012 | Sharper Image Air Purifiers
Filters are clean, soft cloth used to wipe inside of each filter slot down...not so much worried about the constant clicking, as much as I am the unit running 5mins and shutting off, or the alarm sounding...
These are usually quiet so the clicking might be an problem. It could just be a dirty ion generator. On this unit you can toss those into the dishwasher. If they are dirty enough the click you hear might just be a spark. If it is sensing this it might be why it is shutting down as well.
I've included a link to the manual for the unit so that might help you out in settings and so on.
This is the pdf manual
http://www.brookstone.com/webassets/pdf/630285p_manual.pdf
This is a link to the product page, at the bottom is the tab for warranty and manuals.
http://www.brookstone.com/pure-ion-pro-air-cleaner?bkiid=SubCategory_Home_Home_Comfort_Air_Cleaners'SubCategoryWidget'630285p&catId=L3_AirCleaners'L2_HomeComfort'L1_Home
I would download and read the manual, clean the unit according to the manual and see if that makes it behave. When these work they are incredible at what they take out of the air. We used a commercial version of this unit in a 13000 sqr foot room and even with a few hundred people who smoked (was allowed at the time) the air remained clear. The ion traps were revolting disgusting when they were cleaned once a week so they definitely pull stuff out of the air.
Sep 12, 2011 | Brookstone Pure-Ion (506840) Air Purifier
Our Brookstone air purifier sounds like a bug zapper in spite of cleaning filter. It's less than a year old. What is the problem?
have you cleaned the connections where the filter connects . There is prob dust and dirt down inside the filter , keeping it from making a good connection. The zapping sound is from the electricty jumping the gap. A good cleaning of the inside should help. Try attaching a small hose to your vac to fit down inside the unit. give the electrical connections a good cleaning . If that dosen't work take unit apart and wipe down with alchol that you can buy at any drugstore
Aug 12, 2011 | Brookstone Pure-Ion UV Air Purifier
My purifier says to "perform
Krowan - You will need to remove and clean th efiler on the back, remove and clean the ceramic or glass plaques, as well as clean any dust accumulation inside the uint itself. This cam be accomplished by using canne compressed air with a straw nozzle (like you clean your computer with). Just be sure not to blow dust in your eyes.
The filter you can back flush at the kitchen sink, using warm rater. Allow it to thoroughly dry, before reinstalling it. Th e plaques can be cleaned using unscented ammonia and and old tooth brush. Rinse the thoroughly, place between 2 towel to dry completely, before reinstalling them.
That's about all you need to do. Make sure you reinstall the parts properly and that the filer is triggering the safety device.
To further help you, here's a link to the Owner's Manual, that you can download and print for future reference.
Hope this helped you.
Jun 22, 2011 | Ecoquest Fresh Air Air Purifier
XL and Beeeze Filters
If you e-mail to miller@healthyti.com, they will email cleaning instructions to you, free of charge. They are far too long to post here. These instructions are more detailed than the ones that Ecoquest supplies on their website.
Jul 16, 2009 | Ecoquest Living Air Classic Air Purifier
Ionic pro problem
Try cleaning the springs the the blades connect to, they're probably making a bad connection due to dirty springs.
Apr 20, 2008 | Ionic Pro CA500 Air Purifier
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Spring Air CS-1 Air Purifier Logo
Top Spring Air Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Spring Air Air Purifier Expert? Answer questions, earn points and help others
