Question about Western Digital (WD5000YS) 500 GB SATA Hard Drive
Won't Boot Windows 7 disc
    Scholar:
  • 40 Answers
Try starting with dvd drive disconnected, it may be the firmware caused the problem.
Also see if you can start in safe mode and uninstall the the last updates if the above fails.
Or, try Tenorshare Fix Genius directly, it can help to scan the error and repair it.
Posted on Feb 22, 2013
  • Western Digital Master
  • 27,725 Answers
It could be a problem with the cd/dvd drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive Hope this helps.
Posted on Jan 05, 2013
New Screen in Laptop but Windows 7 Won't Boot
Check the windows repair or even reinstall windows with a disc so that everything is detected.
Jun 13, 2013 | Microsoft Windows 7 Ultimate for PC
Administrator password
You may have to contact Dell directly if its a hard drive or BIOS password.
I do know using a Windows 7 install disc will repair this error (if you can get past the password). Just insert and choose repair. gl
Jun 10, 2013 | Dell Inspiron 8500 Notebook
My Medion laptop won't boot windows; black screen
Unplug, remove battery, Remove and reseat Memory Mods, try to reboot. If no, Remove HDD and test, replace if necessary. Has their been any damage? Dropped?
Feb 02, 2013 | Computers & Internet
My computer wont boot correctly
won't boot at all?
it's probably the BIOS settings
go to the BIOS settings by pressing F8 or DEL
go to advanced settings
look for "boot device priority" or something like that
set the first priority device as your harddisk
save & exit,restart,happy computing
the "boot device priority" maybe not placed on advanced setting,each BIOS has different interfaces,just look for something like that,it's easy
Aug 22, 2012 | Gateway NV53A24u Laptop
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Can you upgrade to windows 7 with out a disk
Yes you can, you can make an USB installation for Windows 7, then boot from the USB stick via bootmenu or bios.
http://kmwoley.com/blog/?p=345
and you can download iso files of windows 7 and mount them using Alcohol 120% or deamon tools, then you won't have to burn to disc
May 16, 2012 | Computers & Internet
Won't Boot Window 7
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 15, 2012 | Computers & Internet
INSPIRON 1545 WON'T LOG IN MESSGE READS 'THE GROUP POLICY CLIENT SERVICE FAILED THE LOG ON ACCESS IS DENIED' RUNNING WINDOWS 7 HOME PREMIUM
Are you able to get to the desktop in safe mode?
Repeatedly press F8 on startup and choose to boot to safe mode in the options window.
Mar 28, 2012 | Dell Inspiron 1545
I own a Dazzle DVC170 and i lost the studio disc that come with it. I want to run my dazzel on my windows 7 laptop and use camtasia to edit it. But it says it is not compatible with this 64-bit versi
You won't be able to run it then. It is like trying to run a petrol engine on diesel- it won't work. The software has not been written for Win 7 or, from what I can see on the website, a 64 bit Operating System. Sorry.
Mar 13, 2012 | Pinnacle Computers & Internet
Shut off in middle of system reboot to earlier date and will not boot up now.
Hello
The fault should be of its bios backup battery. It is 3V disc battery. Just switch On the system, and press 'delete' button during boot up to enter its bios settings, and see whether the time is correct. If not set the time and reboot again and see whether it boots up normally. If it does, and it won't boot up normally after shut down, repalce the battery with a new one, set time as dectibed above once again. The system will be alright. OK.
Jan 21, 2012 | Toshiba Satellite P105-S6197 Laptop
Western Digital (WD5000YS) 500 GB SATA Hard Drive Logo
51 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
