All status lights lit and projector not projecting
All status lights were lit at same time. Unit would not project. Tried unit later and it worked fine.
  • Laura Corrigan Jan 07, 2013
    I will try this if problem happens again. Thank you!
    Genius:
  • 1,669 Answers
Cycling power off and then on again after a few minutes may have allowed the unit to discharge its circuits and reset itself.
Posted on Jan 04, 2013
    I will keep this in mind. Thank you.
  • Duane Smith
    Duane Smith Nov 19, 2013
    Hello, If UX60 projector - if you check the lamp cover, there is a small slot where part of the lamp cover comes in contact with a switch hidden inside the Projector cover. This switch is small and haphazardly connected to the Projector cover (cheap plastic). Anyway, if the lamp cover does not push the switch "contact" the lamp with not come on and it just cycles...as you witnessed. You can replace that switch OR carefully open the Projector cover and used electical tape to tightly wrap the contact switch...so it is always on or in contact. Replace cover and presto - Happy Happy.
4 Suggested Answers
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
  • 3 Answers
SOURCE: computer screen doesn't project onto wall
There is a function f-key combo that you need to toggle on your laptop. I'm assuming that you are just using a laptop. Depending on the manufacturer, the f-key will have either a square with a line beside either side. Maybe it says ctr/lcd, or it looks like two squares side by side. You will have to press the fn key at the same time as the corresponding f-key, up to three times, depending on manufacturer.
Posted on Dec 29, 2008
SOURCE: Won't project; can't find signal
What worked for me was instead of pressing Fn while pressing F8. I pressed Fn and F4. The first time doing this my laptop screen went black, but the image was projected on to my projector. When I did this once again the image then appeared on both my laptop and on my computer.
Posted on May 17, 2009
Less than 1 year old Projector squeals and projects green screen (ceiling mounted). Filter not blocked - no warning lights lit. Should the fan run after the unit is turned off to cool the lamp? Other...
84+, the fan will stop while you trun off the projector ,at the same time
it is no problem
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 25, 2011 | Epson Corporati PROJECTOR, EPSON,...
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
Feb 10, 2008 | NEC VT460 Multimedia Projector
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
No lit / projected image even with a new bulb!
Let me add...
I had one 3300MP and removed/replaced the bulb to dust off as it was overheating. There is a small metal like switch that resets the bulb replacement (physical switch - take a good look) -- This helped to reset the first time I did this, but doesn't reset the hours on the chip.
However, since this bulb was problematic for me, I have done this a couple of times and since has stopped powering the bulb now. So, thinking it was the bulb, I replaced the bulb, -- No good... So, thinking it was the projector, I bought a new/refurbished one on ebay -- tested the NEW bulb - NO GOOD. now I have TWO PROJECTORS, THREE BULBS and NOTHING THAT WORKS...
WHAT AM I DOING WRONG?
Apr 27, 2007 | Dell 3300MP Multimedia Projector
823 people viewed this question
jasbo
jasbo
