Question about Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover
Sony xplod 1200 watt
Hey i have a 1200 watt sony xplod competition amp 5 channel hooked up to a 12 inch audiobahn in the my trunk the amp is in my backseat and when i turn it up past 25/35 volume the amp cuts out and a red light flashes on the top of the amp. at first i thought it was over heating but then it persisted even at night... this amp has never given me trouble like this... im thinking maybe the fuses are dead or maybe the one under my hood is. Any help will be greatly appreciated
I had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Posted on Mar 07, 2009
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp going into protection
Is the amp bridged? If you only have one speaker connected to it, I sure hope so. How much power can that speaker safely handle and what is the impedance of the speaker? 2,4,8 ohm? A 1200 watt amp with only one speaker may be too much amp.
Jan 14, 2014 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover Logo
378 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
