Question about Dryers
Drum often need manual turn before it starts to turn
My guess would be a loose belt or motor brushes.
A quick inspection (top and rear panels removed) would appear to show belt is OK
Looking at spares suppliers I cannot find anyone selling motor brushes
Even with back panel removed the motor is not accessible - should I 'go in' through the bottom to check the state of the brushes?
All advice appreciated
Allan Brayshaw
  • 135 Answers
Tumble dryers dont have brush motors they are started by a capacator which will be on or around the motor.
It is about the size of a pepper pot with wiring to it.
These are cheap to buy and if the drum turns after you give it a push then this is the culprit.
Hope this helps & thankyou for using Fixya.
Posted on Jan 19, 2009
What is wrong with a Frigidaire front load dryer whose start button light comes on but drier just humms.
Most likely the belt has slipped off the drum. It might have also worn out. The process to repair it is a pain. You did not post the make and model but if there is a kick panel under the door you can remove that easily to check the belt. Unplug the machine and remove the screws that hold the panel. They are under the bottom edge. Take the panel off and get a vacuum cleaner and clean out all the lint. Use a light to see the belt and the motor. You can use your hand to turn the drum and see if the motor turns or you can check it by close inspection. If the belt is off the pulley you have to take the whole top of the dryer off to get to it. Check the back for screws and remove any that hold the top on. The top lifts off of the unit and it make take some serious pulling to get it loose. You can then see into and around the drum.
Dec 08, 2014 | Frigidaire Dryers
It is not spinning
check belt, remove top, (2 screws at rear), belt sits on plastic disc at rear of the drum, if not there it may have come off/ snapped. remove 2 screws in plastic cover and remove cover at bottom rear. if belt is there u'll probably need a new one. There may be other issues.
if it doesn't spin manually then probably need to replace bearing. clean filters etc first may be something simple. large black tube under drum to rear beside drainage. remember could get messy. if this doesn't allow for turning then probably bearings need replaced. u'll know if there is evidence of grinding on the disc that the belt sits on if bearings need replaced.
if turns manually and belt is still on almost certainly electrical/ motor issue. check using voltmeter to see if power getting into motor, if not u'll have to know how to fault find. if power getting to motor then could be brushes or burnout
probably a few more things but these are most common
Jan 08, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My dryer is a frigidaire, and when i turn it on yo...
The humming is the sound of the Electric motor that drives the drum to spin
You will need to remove the top & the front panel to repair.
First just remove the TOP panel only for inspection
On the top's rear side you will see two small brackets with screws in them. The brackets attach to the Top & the rear panel to secure the top on
Remove these two screws
Now go to the front & pry each front corner up with a flat head screwdriver between the top and the front panel
Spring steel retainer snaps holds that into place and will not break when prying upward
Remove the electrical connectors and mark them with tape if wanted were they connect to for reference
Now look inside the dryer and you will see the drun and the belt should be around this drum. If not replace the belt. You will need to remove the front panel side screws to remove the front panel to remove the drum. The belt tensioner hhas a roller on it too which will need replacing.
Reverse procedure to install
May 20, 2010 | Dryers
CLUNKING NOISE WHEN SPINNING SAME SOUND WHEN TURNING MANUALLY
Have you tried turning the drum with belt removed to see if sound is from drum or motor.If you cant get at belt easy thru. top ( make sure power is off) then you will have to split the casing which will give you a great view of all the moving parts to see if any loose parts.It may be that the bearings have gone so badly that it is clunking as it turns.Normal bearing failure noise is a rumbling.
Remove 2 screws at rear underside of top lid and remove.On top middle either side by springs remove the 4 screws holding back panel,down below at rear there is normally 2 or 3 screws on corners of panel,now go to side of panel bottom middle by seam and remove round white plastic covers put small screwdriver in hole and pull out there is a screw behind each (8mm small socket).Now by water inlet valves prise out white plastic housing with valves still inside now put screw driver in spli on side panel either side and work it back you will have to hold down drain hose to clear panel,once off you can inspect for any damage or loose parts,check drum pulley is not loose or worn,check motor also concrete balance weights one on back top of drum casing and one at front around door seal,sometimes these come loose.To refit casing it is a reverse of removal.
Hopefully this will be helpful.
Good Luck.
May 05, 2010 | Zanussi FLA1001W Front Load Washer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Dryer make a squeeling noise when going, how do I fix and get the back off the dryer
Nothing could be easier to work on than these beautys. After unplugging the machine start by popping the top so you can get to the screws holding the front panel on. As pictured gently push the springclips in on each side about 2 or 3 inchs from each end to release the top: top%20removal.jpg Pop that top with a putty knife. After removing the 2 phillips screws holding the front to the frame (near the top on each side) and taking the wires loose from the door switch, lift the front panel out yer way.
Remove the rear hatch and take the idler loose. Then you can get the drum out. Grab the belt and yank upwards on the drum and remove it out the front.
INSPECTING THE DRYER Look for broken glides on the front panel: 5303937139.jpg?height=147&width=200 5303937139 glide kit $24 The rear drum has a big trailer ball type mount that holds it into place, over time the plastic bearing wears out and the support under it squeals, (it is telling you serious stuff is going to happen) The metal mount under the by now thin, failed, and gone bye-bye plastic bearing, will eat into the ball and cut it off causing the drum to fall into the heater element AND break the belt. YIKES! NOT GOOD! a%20frigidaire%20dryer%20bearing%20failure.jpg?height=150&width=200
Failed bearing with missing ball
The kit (5303281153) comes with everything you need to repair the bearing. It is about $25 bucks or less. With the drum removed and the bearing inspected you want to take a gander at the heating element. If the element is broken, there is no need to buy the whole pan for $100. You can get a restring kit for about $25. Just remember to evenly space the new wire so it will not burn out quickly. Remove all lint from the dryer and the drum. This is the main killer of a heater element. Lint on it causes a hot spot. gibsonfrig%20elec%20coil.jpg 5300622032 Restring kit $25 The fuse mounts on the rear wall of the dryer in the upper right hand corner. If it blows the dryer will not run. Clean out the vent and any lint in the dryer or the fuse will continue to blow. gibson%20rear%20wall.jpg 134120900 Fuse $12 The belt part # is 5303281154 $10 The Idler is part # 131863007 $12 For routing info see Belt routing above on anotha page my friend. LOL Or better yet how about the repair manual? Here is a newer repair manual. The innards of the dryer is the same as always but the newer models have a thermister and assorted goodies: ELECTROLUX REPAIR MANUAL
Oct 24, 2009 | Frigidaire FDE336RE Dryer
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Dryers Logo
70 people viewed this question
Top Dryers Experts
