Back to:
Tags:
Panasonic PV-C1320 13 in. TV/VCR Combo
How many watts does the tv take, anybody know?
posted by soccerplayer on Jun 27, 2007
i need to find out how many watts the tv takes to see if i should buy the 400 watt dc to ac converter.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 27, 2007
Not Rated (0)
Noggin
Rank:Guru Guru
Rating: 88%, 1577 votes
Here's the link for the user manual if you need it;
http://service.us.panasonic.com/OPERMANP...
Check page 39.
120vac - power on = approx 69W
I wouldnt get an inverter too close to that figure, but a 200w inverter should do - just check the inverter specifications to verify if the rating is actual power output - many inverter manufacturers are a little creative with their model names etc, but the real info has to be somewhere on the box.
If in doubt then the best way is to evaluate your battery system capacity and usual recharging input, and match the current drawn by an inverter to half that figure, see what power inverter size you can manage. if you buy bigger, you get more watts per dollar usually, and you may want any surplus capacity later for another item.
Also running inverters up towards their maximum often will shorten their life dramatically.
Hope this helps :)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how many watts does the tv take, anybody know?:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
my television is locked how do i unlock it.
I have a Panasonic tv/vcr combination, PV-C1320, I get...
how can i manually program the tv
Hello All, I have a small Panasonic TV, Cable&VHS...
I have a panasonic tv/vcr combo, model number PV-M1326...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
