Question about Winter Sports
Polaris snowmobile head light dose not work. seems like a ground problem
Wiggle high beam switch and the light works. replaced switch still has same problem. where else dose the light get a ground from?
  • 12 Answers
SOURCE: 2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
  • 35 Answers
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Posted on Feb 17, 2010
  • 35 Answers
SOURCE: replacing snowmobile track slides for 94 polaris
remove the screws from the front part of the rail that holds the hifax on, then slide it backwards through a window in the track, same procedure on instalation
Posted on Feb 19, 2010
  • 39 Answers
SOURCE: what is the ajustment for oil injetion on a 600
The oil pump should be below the carbs or to the right of the recoil.
Posted on Feb 22, 2010
  • 46 Answers
SOURCE: polaris snowmobile spark plug wire replacement
THEY ARE THREADED ON . TURN IT COUNTER CLOCKWISE TO REMOVE IT AND CLOCK WISE TO INSTALL IT
Posted on Jan 06, 2011
Left operating headlight not working
the switch supplies power to the relays that switch on the lights according to the position you have it at
so on high beam there will be 2 high beam lights working
on low beam there will be 2 low beam lights working
back to passing lights or flashing head lights , both beams will work so the switch is the last item to consider
Now with only one side beam not working it comes back to the ground on that light for that bulb
remember that electricity follows the path of least resistance so it the ground is bad the current will ground out through another point including a light which will switch that light off or make it not work
remember the brakes light that flask when an indicator is used --same thing
Jan 24, 2016 | 2000 Nissan Maxima
One low beam head lights will not work, high beam works though
check for a damaged wire for the low beam. Also wouldn't hurt to check the ground wire as the high beam will try and ground through the low beam but not visa verse
Dec 29, 2013 | 1997 Chevrolet Blazer
I replaced the low beam headlight on the passenger side of my 1997 Blazer, but it still won't work, the high beam works fine.
check for a bad ground or check plug and back track wires with test light till you get power and fix the wire. Make sure you check for a good ground first. If all fails then run a new wire from the other low beam light to the non working one.
Feb 03, 2011 | Chevrolet Blazer Cars & Trucks
Blowing low and high beam bulbs as well as rear tail light bulb. 2001 polaris 600 touring
Have you replaced your voltage regulator recently. This is usually a good indication that it should be changed
Feb 02, 2011 | Polaris New Genuine Polaris Snowmobile...
Lights are dim sometimes come on bright now always dim and when i hit the high beam button headlight shuts off completely
THIS SOUNDS LIKE IT MAY BE A VOLTAGE REGULATOR AND POSSIBLY A HEADLAMP BULB OR SHORT IN THE WIRRING. REMOVE THE BULB AND CHECK IT TO ENSURE IT IS NOT BLOWN ON HIGH BEAM
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
LOW BEAM HEAD LIGHTS DO NOT WORK, JUST HIGH BEAM AND PARKING LIGHTS
Welcome to FIxYa.com
Check grounds and head light switch.
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 23, 2010 | 1995 Oldsmobile Cutlass Supreme
My low beams keep shutting on and off but high beams are fine
this could be solved by taking the bulb out of its holder and cleaning the contact of the bulb and holder.
turn the ignition on after this with the bulbs in the holder and plugged in but not in the headlight kitself.Turn the lights on and see if the work if still the same try moving the bulb while on in its older and see if its just loose. if so holding it one way it will work. wedge something something to hold it in place or buy a used bulb holder.
Check the fuses at the same time and the wire plug that powers the bulb. check and clean the contacts of these also
Let me know how it goes and ill help again if it persists.
bakerboy11@hotmail.com
Automobile
May 17, 2010 | 1994 Dodge Ram
Left headlight is dim - like it has a bad ground. Right is fine. DRL are same as regular lights. High and Low beam on left same dim condition. Fuses are OK switch checks OK. Replaced the relay with no...
i think you hit the nail on the head with the ground problem,if you remove the bulb from the head light assembly,wiggle the black wire to see if the bulb gets brighter,if it does remove the bulb and clean and tighten the ground wire end.if it does not get brighter from a wiggle,connect the ground end of a test light to the positive post of the battery and probe the black wire,test light should light,if so replace the light socket.
Nov 26, 2009 | 2000 Chevrolet Blazer
Feb 23, 2009 | Polaris New Genuine Polaris Snowmobile...
1999 Chevrolet Astro Van problem
the head lights have tree wires goig to it one groun one gets power when high beams on the 3rd gets power only with low beam on test the wires or try by plugin a good known head light to conector if it works with low beam then replace both head ligts because head light come with two bulbs in one high and low
Jun 02, 2008 | 1999 Chevrolet Astro
Winter Sports Logo
44 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
