Question about Samsung Sp46k5hd / Sp50k6hd / Sp56k6hd / Hls4676 Projection Tv Lamp W/housing
The lamp is not working model sp46k5hd
Stand by/temp and lamp ligths are flashing
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
  • 16 Answers
SOURCE: Samsung DLS not working(with new lamp)
The grinding sound is most likely the color wheel. The lamp will not fire up if the computer senses the color wheel is not in motion or turning too slowly. It does this to protect the color wheel from being burned.
Something else you need to realize is the fans sometimes make some noise(especially the fan at the rear of the DMD Board).
The Ballast does not go bad that often and is misdiagnosed more times than it actually needs to be replaced. Sometimes the DMD Board is defective and won't send the color wheel the signal to start which in turn doesn't let the lamp turn on. I have read this misdiagnosed as a bad lamp, ballast, and color wheel multiple times. I currently have two of these in my shop at the moment and they were both verified by swapping known good DMD Boards.
There is some very good information available on this site but many times it isn't that simple of a repair. You need to get all the information and verify before buying parts. Most of the time it will pay for someone to have a reputable shop do a repair rather than buy parts that are not needed. I have had three people buy lamps in the last week, and two replace capacitors, only to give me a call and fix the problem correctly. All of these people got the repair tips from the internet.
Posted on May 07, 2010
SD Tech
  • 14553 Answers
SOURCE: HL-R5667W Picture just went blank, no sound. When
two things to check here:
1. remove the lamp and examine it to make sure it is not shattered inside.
2. if the set had a high pitched or fan like noise before it failed, the color wheel needs to be looked at--I can tell you a easy way to do this.
Look at the lamp first--life span is 2000 hours.
I am here to help and the more you tell me the better I can help you.
SD TECH Steve
Posted on Jun 10, 2010
Testimonial: "Thanks. I will look at the lamp and the digital board."
ladywinn
  • 5138 Answers
SOURCE: I have a Samsung HL-S4266w TV When I plug in tv I
You need to replace the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-844-7871
Posted on Oct 25, 2010
ladywinn
  • 5138 Answers
SOURCE: stand by/temp, timer and lamp lights flashing.
Replace the Lamp .Mats has them for $99.00 1-800-628-1118
Samsung parts.com 1-800-627-4368
Posted on Oct 28, 2010
Pt50dl14 i changed the lamp turned tv on. bulb lit then shut down within seconds. now the lamp and stand by/ temp. are flashing and tv will not turn on?
If Akai brand that is Samsung (they own the name).
I have a simple suggestion-----remove the lamp with cartridge (set unplugged) and look where the lamp faces-----the color wheel this model uses fails--I will attach a photo.
What you are looking for is: are any segments missing or the wheel even shattered?
These fail often and the set if wheel (turns at over 8,000 rpm) slows down, shattered, or missing pieces the set will detect that and turn the lamp off almost instantly.
Let me know as if this is the problem it can be a do it yourself replacement as You Tube has video instructions for this on most models.
Apr 13, 2012 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
95 f150 inside ligths stad on tok + cable off battery took fuse out to cut the ligths next day the over drive ligth starter flashing HELP
Im not sure if this is going to be your problem but on f150s 250s 350s rangers and explorers, have very weak door switches that are used to tell the dome light to go out, when it fails the dome light does not go out if you have left the fuse out for the dome light there will be other problems, on most models the fuse that the dome light is on also controls the odometer, windsheild wipers and the electronic shift for the overdrive, generally a quick fix for the problem is to remove the bulb for the dome lamp, and insure the fuse is in properly, if you have map lamps in your vehicle these should still work, the only issue is you will not have a dome lamp when you open the doors only the map lamps youll have to turn on manually, If this does not fix the error with the overdrive most likely have shorted door switches throwing the circuit for a loop
Apr 01, 2010 | Ford Explorer Cars & Trucks
I have a Samsung HLS4266WX/XAA that keeps turning itself off with the red stand by/temp light on in the front. I have allowed it to cool down for over an hour with a box fan pointed on the back of the...
Dear dreadtrainer;
It sounds like your Lamp is going bad. The part # B96-01472A. Go to internet (like Google), enter Model # and Lamp toget your best price. To replace the lamp is easy, look at your 'owner's manual".
Good luck, Big Irish.
Nov 13, 2009 | Samsung Televison & Video
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung Sp46k5hd / Sp50k6hd / Sp56k6hd / Hls4676 Projection Tv Lamp W/housing Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
