Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Sytem error C6050 kyocera 3035 - Kyocera Mita KM-3035 All-In-One Laser Printer
  • 36 Answers
SOURCE: Sytem error C6050
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Posted on Jan 18, 2008
  • 66 Answers
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Posted on Apr 03, 2009
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
talandinho89
  • 4 Answers
SOURCE: Kyocera 2520 error c6050
it happen because there is problem with termostat of the heater unit
change that thermostat or connect the tow wires with each other
Posted on Dec 15, 2011
What do I do with the error code of C6050 on a Kyocera KM-3035 machine
You need to go into simulation mode and enter U163.
This simulation number needs to be reset.
Nov 09, 2017 | Kyocera Office Equipment & Supplies
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera codes
my dear you chek heater unit and fouse
Jun 05, 2014 | Kyocera Km-3035 Copier, Print,scan,fax ,...
Sep 02, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Error Code C6050
May 25, 2009 | Kyocera Mita KM-2050 Printer
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Sytem error C6050
Jan 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
121 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
