Question about Samsung Washing Machines
Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
Dv210AGW/XAA dry will turn on when I press the on botton but the drum does not turn nor does the heat come on when I press start. Also, tested on auto and maual, nothing. Should also note that I tested with and without cloths, nothing still. And the clock does not count down but left on, the dry thinks it completed and the wrinkle free alarm sounds and then it ends. I opened the unit and the belt is fine, drum spins manualy and/or if I spin it via the fan attached to the motor. any clues into the issue. Oh, lastly, ran it last night with a light load, no issues. this morning, put in a pair of jeans and nothing."
  • dkpashos Jan 04, 2013
    Sorry, made a wrong comment about the clock not timing does, it does time down. Also, as noted, there are no error codes. If I open the door while I wait, it does error as it should so the panel looks to be working as expected
Hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
Posted on Jan 04, 2013
SOURCE: Frigidaire GLTF2940ES
Is it draining completely?
Posted on Feb 07, 2008
IB4G2008
  • 3587 Answers
SOURCE: Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Posted on Feb 18, 2008
  • 106 Answers
SOURCE: damp clothes at end of spin cycle
Time to check out and clean your filter...........
Posted on Mar 01, 2009
  • 7 Answers
SOURCE: how to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Posted on Apr 03, 2009
  • 155 Answers
SOURCE: slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Posted on Sep 02, 2009
Dryer has power, displaying no error code but will not run when I hit start
Try rebooting the electronics, by unplugging the power cord for 30 seconds. Then, plug it back in and try again. Can you give us any more symptoms?
Dec 23, 2015 | Samsung DV210AGW - 7.3 cu. ft. Sensor Dry...
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Washer will not turn on
The main PCB control board has failed & will need replacing. I would recommend using a qualified technician to change it over.
Sep 01, 2015 | Samsung WF210ANW Front Load Washer and...
I have a Samsung DV5451AEW/XAA dryer that will NOT shut off. It ran a cycle and finished drying. The panel is now turned off and non responsive, but the drum is running without heat. I have left the dryer...
Sounds like you have the spin relay for the drum, stuck in a closed position. If you can locate where it is, you van give it a few taps to get it to disengage. You will then have to try to clean the contact on the relay that is sticking with a toothbrush and some spray contact cleaner that is safe for plastic. If this doesn't work, you will have to replace the relay or the contact. I hope this helps.
Mar 02, 2015 | Samsung Washing Machines
Does Samsung DV448AEW/XAA dryer have a reset switch ?
If it over heated most dryers use thermal fuses. They must be replaced if they have blown. Samsung is one of the most difficult that I have seen.
samsung dryer not heating YouTube
Searching Model For Search Your Way DV448AEW 4
SEARCH SAMSUNG
Oct 10, 2014 | Dryers
Dryer does not dry. Wont heat up.
I am directing you to Repair Clinic.com as that will help you diagnose the issue that you are having as there isn't enough info for me to get specific info for you!
The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160d1420640-x73616d73756e67206476353437316165702f786161/Samsung-Dv5471aep-Xaa-Model-DV5471AEPXAA-Samsung-Dryer-Parts
Good Luck!
Rich Lilja
Oct 06, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
Dryer drum not turning
First...just as a reminder that electricity can kill! Unplug the dryer and slide it out so you can get to the back of the dryer. Remove the back panel. Plug the dryer back in and observe the dryer in operation. If the belt is broken you have your obvious answer. If nothing happens then UNPLUG the dryer again and reach in and remove the belt from the motor. Plug the dryer back in and attempt to run it again. Does the motor spin? If not, dead motor. It is not the thermal fuse because you say it heats up. Take a look at this video for additional help.
Nov 29, 2017 | Samsung SM-DV210AGW - SERVICE MANUAL
Washing Machines Logo
226 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
