Question about Garden
How can I set the proper air/gas ratio on homelite 10618A chain saw?
My Homelite 10618A won't crank. It will only if I take the plug out and then put a little gas in the chamber, put the plug back and crank it. It will go for a moment or two and then die. Any suggestion for adjustment?
    Sergeant:
  • 391 Answers
Salvador:
GENTLY turn the air/gas mixture screws in all the way, then turn them out one and a quarter (1 1/4) turns out. The saw should start. Adjust from there. If the saw doesn't start, the fuel isn't getting from the tank to the carburetor or the carb is gummed up and needs rebuilding!
Posted on Jan 06, 2013
    Sergeant:
  • 137 Answers
I recommend to any of you that have small 18" or less, homelite, poulan, McCullough, etc., is to pick up the saw and empty out fuel and oil and walk over to your nearest trash can, lift the lid and throw the garbage in where it belongs. Even the manufacturer's know they are garbage , because on the manufacturer's paperwork it says theses saws were made for light duty and a maximum of 150 hours of use.
150 hours is four weeks of use or a few months of weekend use.
My strategy lately is to have one real saw for heavy work..a Stihl 750 with 36" bar, which has worked faithfully for 30 years with virtually no maintenance from me.
For my sanity, I gave up on those small gas saws and switched to electric saws....and I love them. No noise, no friggin pulling the starter cord for 3000 pulls no trying to figure out is it the gas or oil or fuel mix or H or L buttons...and whatever. One moving part...a motor..that's it.
I'm getting so used to the light weight and no problems and quietness, I only use my Stihl for extreme trees that are 3 foot thick or more. I even use the electric saw for deep in woods use by carting into the woods a small generator to plug the saw into.
Simplify simplify..you'll be a lot happier. By the way, some electrics are better than other's. I've used craftsmen and Remington because they are really cheap ( like 70 dollars) and occasionally I have fried the plastic teeth off the "clutch" teeth when I get a blade stuck, but I just order three or four extra and get them online and I'm back in business in minutes. I hear Stihl and Echo make a good electric saw, which costs quite a bit more and maybe they have metal teeth and don't have that one problem I have with the cheap electric saws...but I'll take that small problem any day over those highly unreliable small 2 cycle chain "broke" saws
Posted on Jan 27, 2015
SOURCE: need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Posted on Feb 06, 2009
SOURCE: homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Posted on Mar 17, 2009
slohry
  • 87 Answers
SOURCE: I need a manual for homelite chain saw 14" ut no. 10655 ser.
50:1 if you use good oil (i.e.Husqvarna, stihl, echo)
32:1 for lesser quality oil.
Download manual here. have UT# available
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
SOURCE: HOMELITE Textron Chain Saw, wont stay running properly.
left my chain saw xl12 in the garage and the gas dried up need to rebuild the carb and clean up the gas where do I get a gasket kit so I can start for this unit
Posted on Feb 24, 2010
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
What is the homelite chain saw 360 Gas/Oil ratio ?
2.8 oz per gallon will get you very close to a 50/1 ratio. 3.6 oz per gallon will get close to 40/1
May 21, 2014 | Homelite ZR10926 16" Chain Saw
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Chain saw won't start
Are you priming it Salvador?Check the plastic bulb,may be cracked and not putting gas in the chamber.
Jan 04, 2013 | Garden
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
Jul 04, 2012 | Suzuki Motorcycles
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
Nov 18, 2011 | Homelite Carburetor Trimmer Blower...
WHY IS THERS GAS IN MY CRANKCASE
Hello
Check that when you switch off you mower and leave it that the carb is not leaking in to the combustion chamber and then past the rings in to the crank case.
Thanks
Jun 14, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
