Question about RCA Televison & Video
Universal remote for RCA tv channel 1
RCA remote cratered, purchased multiple universal remotes. Each instruction starts with tuning the tv to channel one....without a remote that is not possible. Using the up/Down button alone will not get me to channel 1. Can you tell me how I might be able to use a universal remote when I don't have the original remote to reprogram with?
    Top Expert:
  • RCA Master
  • 37,878 Answers
Something missing here. There is no channel 1 on a TV set. None of the universal remote instructions I have or have seen specify that as a first step. From your post, I believe you want to use some kind of universal remote to control an RCA flat panel TV, Can you tell me the brand of universal remote you are trying to use? The answer to the last line of your post is you don't need the original remote to "reprogram". That's what universal remotes do
Posted on Jan 04, 2013
  • sherri feely Jan 04, 2013
    I have purchased 4 different ones before giving up. Each one started with, "tune your tv to channel 1". Since I don't have the remote to the tv and the button on the tv only goes down to 2, I cannot seem to get the universal's to work.
John-INSG
  • 312 Answers
SOURCE: I have a 32 in insignia and a universal remote was
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Posted on Jul 02, 2010
SOURCE: I have a technika lcd19dvdid307 tv and a universal
I think the point he is making is that he only has a universal remote - not the original, so the problem isn't not being able to find the channels, but not being able to select the retune option in the first place. I have same problem - the remotes that shipped with this TV were rubbish (I have gone through 2!) and some buttons stop working. The retune / setup memu is seperate to the other basic set-up stuff and many universal remotes don't have theis 'other' button. Best solution, get a replacement remote that is MADE to work with this TV then you can auto-tune to your hearts content.
Posted on Oct 16, 2009
SOURCE: is it possible to tune
connect ibm x40 to toshiba wlt66
Posted on Sep 08, 2010
  • 146 Answers
SOURCE: i JUST PURCHASED A WESTINGHOUSE LD325 SERIES TV
none of them are very good but you can look into "universal remote" they are a good middle to hiogh end universal remote
hope that helps!
good luck
Posted on Mar 13, 2011
jdvillanueva
  • 2098 Answers
SOURCE: My 32" Philips HDTV is
To confirm if the remote control is working, point the infrared emitter directly to your cellphone camera and then press any key, you will see the flash of an infrared every time the button is press. Watch this sample Video.
Once you've confirmed that the remote control is not the issue, this is an indication of faulty infrared receiver(sensor) inside the tv. Check the front panel of the tv where the sensor is located, clean the surface as much as possible which may block the signal. If the symptoms still persist, I would advice you to look for a qualified tv technician to troubleshoot its circuitry.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Jun 04, 2011
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
Cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Dec 02, 2008 | RCA DIRECTV Satellite Remote Control
RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from Electronicadventure.us for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Nov 15, 2008 | RCA F32650 32" TV
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
204 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
