Question about Emerson MW8102SS 1100 Watts Microwave Oven
MY EMERSON MW1119B STOPPED HEATING
WAS WORKING THEM STOPPED HEATING.
    Problem Solver:
  • 9 Answers
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Posted on Jan 06, 2013
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
I have a Emerson MW1119B/W microwave. It has been doing just fine and all of a sudden it has decided not to heat any thing
Hello there,
When your microwave oven starts to zap, then eventually does not heat up, it means there is a problem inside the unit of the microwave. There are some parts to check inside the microwave before you can tell the exact component that is faulty and to know if replacement will do the job for you.
The three (3) main parts to be tested are the power diode, the high voltage capacitor and the magnetron.
But since all other components are working like the fan, light and clock, then it is most likely the magnetron. Here is how to test and replace the magnetron of your microwave.
HOW TO TEST THE MAGNETRON
Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Magnetron replacement
Have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own.
Hope this helped.
Elect_Comp
Jan 07, 2012 | Emerson Microwave Ovens
Hi, I have an Oster OMW1199 microwave that will not heat food. The light turns on and the timer works, but no heat.
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Aug 28, 2011 | Emerson Fans Emerson MW8115SS Microwave...
Microwave stopped working during heating process....timier works but does not make that microwave sound
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
heatman101
Dec 12, 2010 | Emerson Black Microwave Oven
My emerson mw8117w just stopped working
hi! first thing first check all the fuses for busted.
Sep 15, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Quit Heating
The Magnotron goes out on many of the lower priced models in the first yr.,(and some of the higher end ones too!) As the components there do most of the hard work. Better to just find a recycler who takes them and scrap it.
As for the replacement that sounds like an excellent idea!
Sep 02, 2017 | Emerson MW8778 Microwave Oven
My emerson microwave has stopped heating up but appears fine
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | Emerson Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
231 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
