Dashboard won't load after start up window in windows xp
I click on Seagate Dasboard icon from desktop and from startup window. The Dashboard start up window appears, but it never loads (so that I can access the drive or do anything else).
  • kstreech100
    kstreech100 Jan 10, 2013
    Thank you all for your responses. Seems there were a lot of problems happening. Too much software on my computer, some problems with the Seagate drive so I just erased everything and started fresh (I have another bu drive). Also, downloaded some programs to help with regular maintenance (CCleaner, Advanced System Care, and Smart defrag). Seems to be working better now,fingers crossed!
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 05, 2013
sandrew
  • 2961 Answers
SOURCE: windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Posted on Oct 05, 2007
JLPicard
  • 14 Answers
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
Posted on Nov 17, 2007
bcroydon
  • 9 Answers
SOURCE: SATA Drive
How large is the drive? Windows XP pre SP2 will not recognize a drive larger than 120G when loading from the cd. You will need to use something like Partition Magic to partition and format the drive into 100G partitions, install the OS (it may not see more than the first partition) and upgrade to SP2 and it will see the entire drive.
Posted on Jan 03, 2008
SOURCE: Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Posted on Feb 03, 2008
yammy_alf
  • 666 Answers
SOURCE: windows 7 won't recognize lacie 500 gb hard drive
let it windows 7 format your lacie 500. and check for permission.
Posted on May 02, 2010
Compaq dx2000 mt freezes on startup
Boot into Safe Mode by pressing F8 during boot and...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 12, 2012 | HP Compaq dx2000 Microtower PC Desktop
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
There is a listing available somewhere in Windows wherein you can "quick launch" a program to have it mostly loaded when first turning on the computer ( or have the program deleted from such...
A program can not be 'mostly [or partly] loaded' actually. You can go into the program's settings though and see if there's a way for it to 'Run on Startup', which would load the program when your computer boots up. The only problem with this is that it can slow your computer down and make it take longer to boot up.
Aug 21, 2011 | Computers & Internet
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
How to delete one of two windows xp in my desktop. when my desktop boot, you have two windows xp choices
Edit the Boot.ini File loadTOCNode(2, 'summary'); To view and edit the Boot.ini file:
  1. Right-click My Computer, and then click Properties. -or- Click Start, click Run, type sysdm.cpl, and then click OK.
  2. On the Advanced tab, click Settings under Startup and Recovery.
  3. Under System Startup, click Edit.
This open a notepad windows with the options you see when your desktop boots.
Erase the line you want to eliminate.
This is an example that what you'll see:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect Good Luck. Remember to rate my answer, thanks.
Jul 14, 2011 | Computers & Internet
I purchased Egames Lexicon. When I try to install it a message appears that says it cannot start or run due to incompatibility with 64-bit version of Windows. How can I get this software to work on my...
Right click on the executable file that starts the setup, typically setup.exe. Select Properties. Under Compatibility, set it to Windows XP SP3. If that doesn't work, it really won't work without you setting up a virtual machine and installing a copy of XP. If you're running Windows 7, you can download a Windows XP virtual machine to run. It's called XP Mode. Instructions can be found by searching for XP Mode in the Start menu's Help and Support.
Jul 06, 2011 | E-Games Lexicon Word Challenge for Windows
My Emachine with Windows Vista keeps shutting itself down? What could be the problem?
The first step would be to turn off automatic restart on BSOD errors.
  1. Click on Start and then Control Panel.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel you won't see this link. Simply double-click on the System icon and proceed to Step 4.
  3. Click on the System link.
  4. In the task pane on the left, click the Advanced system settings link.
  5. Locate the Startup and Recovery area and click on the Settings button.
  6. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
  7. Click OK in the Startup and Recovery window.
  8. Click OK in the System Properties window.
  9. You can now close the System window.
  10. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
Now when it errors it wont restart, instead it will give you an error message that we can use to troubleshoot your problem.
I hope this helps! If this did help you, please give a thumbs up!
Jun 28, 2011 | E-Machines eMachines Desktop PC
Explorer doesn't start
go to Start > Run > msconfig
In General tab
make sure you are set to Normal Startup.
Mar 18, 2009 | Microsoft Windows XP Professional SP2 for...
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
