Question about Sharp LC-C4254U 42 in. LCD TV
What is the bolt size used for mounting a wall mount on the back of a Sharp LC-C4254U flat Screen tv
  • 8 Answers
SOURCE: Canterlever wall mounting a Sharp LC -65GD1E.
Yes it is possible as while the television is BIG it isn't actually that heavy.  You will need a very good based to fix up against and I would have to strongly suggest using an expert service from a local AV shop.
Something like this would be ideal: http://www.ebuyer.com/product/130803
Some things to check:
1.  Fix to good quality brick work or very solid wood.  Modern partition walls aren't going to hold the weight and will damage both your wall and the television.
2.  Check the screws and rawl plugs supplied with the cantilever wall mount and replace them if they do not look deep enough or of suitable quality.  Ideally use something like an expanding radiator bolt.
3.  A lot of wall mounts provide more holes in the backing plate than screws are supplied... feel free to use more...!
4.  I like to think I'm pretty competent at DIY... but given how much I like mine I would be cautious and might just upgrade my home insurance to cover "accidents" :)
Posted on Nov 18, 2007
budmrtn
  • 11361 Answers
SOURCE: Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 11, 2010
  • 8457 Answers
SOURCE: TV turns itself off for about 15 seconds then back
This problems is a power glitch happen once in awhile not a problems.Happen all the times,than the Tuner board have problems,must be replaced.That the board where the coalax signal plug into it.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jul 16, 2010
e-Guru
  • 3917 Answers
SOURCE: I removed my Tv stand
You need to call your dealer or customer service for the replacement of lost screws.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Nov 01, 2010
  • 48 Answers
SOURCE: I have a Sharp LC-32SB24U.
Just make an educated guess judging by the size of the bolts you do have, whether they are too big or too small, or you could measure with a measuring tape by measuring the head of the bolt. Then take those measurements to your local hardware or other store and either you will be able to find one you feel confident about size wize or you can find someone to help you. As far as specific bolts go there really isnt a difference, as long as you get a decent size, if its a little too big it will be ok as the threads will just cut their way in regardless.
Hope this helped.
Posted on Feb 07, 2011
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
How do I replace the screen on my sharp lc-c4254u
It is a skilled work. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 08, 2014 | Sharp LC-C4254U 42 in. LCD TV
What is the bolt hole size for mounting a Sharp LC-32SB28UT-A on a wall
Quickest way to know is call Sharp customer service with the model number so you get the correct length, thread type etc bolts--most of course are common and can be found at local hardware suppliers.
Apr 30, 2012 | Sharp Televison & Video
I have a Sharp LC-32SB24U. I am trying to mount my tv to a tv tower stand. There are four screw holes in the back of the tv but the bolts supplied with the TV tower don't fit. The directions say use the...
Hope this helped.
Feb 07, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I removed my Tv stand to my Sharp LC-C4254U tv to install it on the wall now i need to use the tv stand again because i moved and I missplaced the screws for the stand so I need to know the sizes of the...
Nov 01, 2010 | Sharp LC-C4254U 42 in. LCD TV
Bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
I just bought a Sharp LC-52E77U and I need to know what size bolts to use on the VESA mount? TIA Mike
Sharp TV’s takes M6 (6mm)bolts, length depends on the bracket and spacers.
Mar 05, 2010 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
We just set up our 37 in sharp and get no picture
If this is a new set, return it for an exchange. This one sounds like an LCD set which uses a "back light". This back light is not working. This is a warranty repair or exchange.
Dan
Mar 17, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC-C4254U 42 in. LCD TV Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
