I Ran a Quick test from Bios on HP Pavillion laptop, came back as passed. Then it automatically ran a full test @ 56% it stated : "#10008 Replace hard Disk 1 rent test item." Then it immediately ran
I also want to know, whch is the best way to save not just my data, but my programs for the new hard drive since I no longer have key codes nor cd's. I moved twice since I installed most of the software and can't find and key codes nor cd's. Thanks in advance for taking the time to help me.
  • 564 Answers
Unfortunately programs cannot be saved.
Posted on Jan 05, 2013
3 Suggested Answers
  • 72 Answers
SOURCE: Hi!My laptop (HP G7000)can not
Your hard disk has indeed failed, this is not an indication of a spyware problem. Your best bet, if the laptop is under warranty, is to contact HP for a replacement hard drive.
If, however, your are out of warranty or would prefer to do it yourself, it appears your laptop has a 2.5" SATA hard drive. You don't need a huge one, your failed hard drive was probably between 80-160GB. Do not get a hard drive with a PATA/IDE interface, or a 3.5" hard drive, as these will neither work nor fit in your computer.
There are several screws on the bottom of your laptop. You will not likely need to remove the entire laptop case, and many times the bottom of the laptop is labeled with icons or a description of the component beneath the panel in question. When you replace the hard drive, pay attention to the orientation of the old hard drive, as well as where any different size screws were placed.
Finally, you will need to restore your computer with a set of disks. As you will be replacing your hard drive, any restore partition that was previously on your computer will have been lost.
Please let me know if you have any other questions related to this issue. Thanks!
Posted on Aug 11, 2010
  • 343 Answers
SOURCE: Windows Boot Manager message: Windows encountered
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Posted on Jul 23, 2011
My HP Pavilion Entertainment PC won't boot up but displays error code 1720 - S.M.A.R.T. Hard Drive detects imminent failure.
Replace the hdd, install your OS and copy off your date. Reinstall your programmes to recover your backups.
Nov 07, 2016 | HP Computers & Internet
Problems with compaq presario cq56
open f10 go to diagnostics 10008 bios code means the hard drive is fried new one for cq 60 160gb hard drive 90 dollars but might as well upgrade 500gb only 115 i would think the cq 56 should be about the same price
Apr 01, 2012 | HEWLETT-PACKARD Computers & Internet
The message on the screen says primary Hard Disk
Every hard drive has in it a hardware test system - the one from yours has just announced you that your disk has died. Replace it and reinstall Windows.
Jul 22, 2010 | Computers & Internet
My computer wont start up and so i ran a bios primary hard disk self test and it says failed test status 7 (completed with the read element of the test failed) my computer is a hp netbook mini 1000 what...
If it is within warranty, send it back quick-smart.
sounds like the SSD (solid state drive) has died.
i got one of these errors at work on a Dell mini only yesterday!
Jul 13, 2010 | Computers & Internet
HP Pavilion DV6812 is not recovering or restoring!!
If you mean this errors
STOP 0x0000001a (0x00041284, 0xca9a2000, 0x000077e0, 0xc0c00000) MEMORY_MANAGEMENT
STOP 0x0000004e (0x00000007, 0x00007abf, 0x0000f17e, 0x00000000) PFN_LIST_CORRUPT
STOP 0x0000000a (0x00000028, 0x00000002, 0x00000000, 0x8012d2d6) IRQL_NOT_LESS_OR_EQUAL
STOP 0x00000050 (0xc2332b94, 0x00000000, 0x00000000, 0x00000000) PAGE_FAULT_IN_NONPAGED_AREA
Its ram problem,so first if you can access the bios check if your ram are been recognized and load default bios settings.If are OK in bios remove RAM and reinstall again.If the problem still exists try again testing your Ram with the Microsoft program or with that.
If the programs founds an error you RAM are damaged and replace them.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
I ran a dianostic on my system and it stop running when it got to the test for the fan. But my system will not boot all the way could my motherboard be damaged?
if your laptop wont boot it might be a hard drive or windows corruption. just wondering why you ran for the fan test? since you did not mention if test passed the hdd? then turn off laptop then do this. press and hold on the Fn key while holding press the power button once. a test will run then you can let go of the Fn. just complete the quick test PSA check if you will be getting errors such as 0142, 0146 this meas hdd needs to be replaced. if no errors found then try to restore your windows first. make sure you had already backed up your files.
Oct 15, 2009 | Dell Inspiron 1501 Notebook
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
Laptop wont connect to internet
check the firewall settings of your antivirus, or uninstall the antivirus then check
Nov 20, 2008 | HP Pavilion dv1000 Notebook
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
