Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck 9100 Xl blowing out dirt instead of sucking in. Took apart,cleaned & checked belt
Have had this 25 yrs & this time can't seem to fix the problem. Belt is not twisted,bag is new & tube is not clogged. The brush is turning. Help! Thanx, Karen
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning.
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Posted on Jun 03, 2009
  • 206 Answers
SOURCE: oreck xl 9100 bag wont stay on
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Posted on Jul 30, 2009
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
It seems to be blowing the dirt away instead of sucking it in?
Sounds like it has blockage somewhere in it causing low suction, therefore brush 'blows' dirt away instead.
Jan 27, 2016 | Oreck Vacuums
Need a wiring diagram for an Oreck XL 9100 with a amatek motor.Seen one but to small to read.
Jerry, typically the way it should be wired, is the black wire from the handle cord will go to the closest terminal on the motor from where the cord comes into the back of the power head. There should be a black dot beside the terminal. The two white wires should go to a terminal diagonal from the black wire connection and should also have a black dot beside that terminal. The other black wire should go to the terminal beside the terminal that the white wires are connected to. If there are not two terminals side by side then the black wire will go to another terminal that will be on the same side of the motor as the white wire. Hope this helps!
Jan 28, 2015 | Oreck Vacuums
Do you have wirirng schematic?
this is from a previous fixya answer but is works for the 9100 I rewired my 9100 motor connections like this and now does not blow out the lights and work great
Aug 30, 2014 | Oreck Vacuums
What's your problem? Oreck XL Power Team Lightweight Vacuum not picking up dirt
i have just purchased a oreck xl how do i move the handle so i can hoover
the floor
Oct 27, 2012 | Vacuums
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
My vacuum seems to be just pushing around things instead of sucking them up. I changed the bag and cleaned the bottom, but nothing helped.
Did you check to see if the drive belt for the beater brush was broken or frozen up? The beater brush hits the carpeting and causes the dirt, etc, to jump into the air so the suction of the unit can pull it into the vacuum. The beater brush will be fairly easy to remove. Once it is out of the machine, clean it as best you can, add some WD40 on the plastic end pieces and when you reassemble, put a new drive belt on. This should solve the problem. Paul
Oct 11, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Not sucking
You probable have a clog in the handle tube, or at the bottom, either by the brush or in the neck where the handle goes into. Unscrew that big black nut and pull the handle off of the bootom asm, then you can check it out and see where the clog is. Pull the bottom plate off to see if it is there where the dirt goes in.
Feb 17, 2008 | Vacuums
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Oreck XL Ultra Bagged Upright Vacuum Logo
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
