Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
My Dell computer is operating very slowly
The time it takes to respond varies, sometimes at an acceptable speed and mostly not.
  • eblorge Jan 20, 2009
    I do not know how to "defragment" my files. Can you advise me
  • eblorge Jan 22, 2009
    I have a Dell 9100 Inspiron, Microsoft XP system.
    The slowness of my computer is erratic, sometimes it operates at normal speeds, and at other times it takes a long time for any response. This also applies when I get on the internet. Is this a separate problem?
    President:
  • 2,559 Answers
Click start,all programs,accessories,system tools,disk cleanup
Posted on Jan 20, 2009
    Brigadier General:
  • 5,158 Answers
It is likely a memory issue... this can be fixed by adding more memory.. or stopping some programs from running at start up...
it may also be spyware... i recommend spybot s&d which you can download here http://www.safer-networking.org/index2.html
also you may need to run your defrag program
Robert
Posted on Jan 19, 2009
  • Apple Master
  • 13,433 Answers
Tell me more, what operating system? what actually is slow? everything?
Whats the model of your dell?
I will know more ones I have a answer to these questions.
  • Ekse Jan 22, 2009
    Possible reasons for the slowness are
    • Too much software runing on background
    • Spyware or other harmfull software
    • Driver conficts or other driver issues
    • Hardware problem
    • Corrupt files or fragmentation on drive.
    Are you available now? I could have a look around at it over remote support.
  • Apple Master
  • 19,396 Answers
If this happens using Windows, then you need to reinstall Windows first, to ensure it is not the system.
If the computer is abnormally slow, even if you boot on a different system (DOS), then usually it is the RAM.
Do a RAM upgrade, that should fix the problem.
  • Ginko
    Ginko Jan 20, 2009
    Slowness is generally associated with scarce RAM amount. Check the amount of RAM memory, by entering Dxdiag on run box, under start button.
    If memory is less than 1 GB you need to add more memory.
    If RAM memory is OK, check if your computer has spyware.
    Download and install Spybot from link below, and perform a full computer scan.
    The home of Spybot-S&D
    Uninstall Spybot after scan and cleaning is finished.
    President:
  • 1,990 Answers
Welcome to Fixya! Usually this happens when the Memory is Too low. Try to Defragment and Clean out your Temp Files.
  • Travis Humphries
    Travis Humphries Jan 20, 2009
    To Defrag, Go to the Start Menu, Programs, Go to the Top and Select Accessories, Then System Tools and then Disk Defragmentor.
  • Travis Humphries
    You can also Clean out your Temp files with the Utility right above Defrag on this Last Menu.
    Genius:
  • Apple Master
  • 1,102 Answers
Do a virus scan
the more programs you have downloaded the slower your system goes
check control panerl add remove then remove any programs you no longer use
then i do a disk defrag followed by a scan disk
how old is the system
  • 3 more comments
  • DEKR
    DEKR Jan 19, 2009
    you may also want to remove some programs from start up
    the more programs you have set to start at startup the longer it will take your system to start
  • DEKR
    DEKR Jan 21, 2009
    you can do a defragment by clicking start programs then accessories
    then click on disk defrag then when the box open click defrag.
    make sure you shut screensaver off while defragment is running
    you don't want to use any program
    the defrag will sort out your bad segments and files
    then when its done just close off and restart
    let me know if this helps
  • DEKR
    DEKR Jan 21, 2009
    are you still having problems
    if you are i would format but before doing that
    right click my computer
    then properties
    hardware
    then devides
    scroll down and right down driver types for
    NETWORK
    DISPLAY
    AUDIO
    DO YOU HAVE A BOOT CD
  • DEKR
    DEKR Jan 22, 2009
    just wondering how is everything going for you
  • DEKR
    DEKR Jan 22, 2009
    YOU MAY BE DO FOR A FORMAT
    do you have recovery or wincd
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
How to reset memory
When ever the engine electrical has been disconnected for a while such as while you are doing some major work on the engine and you disconnect the battery or even if you switch engines the computer will need to relearn the driving habits so to speak. Start the vehicle and let idle for five minutes the put the vehicle in gear and slowly pull out. Drive in a gentle way for 5- 10 miles then slowly you increase the speed. do not just romp into it. It can take several days of normal driving before the computer has relearned the driver information. I take a nice drive through the neighbor hood stopping at stop signs slowly speeding up and slowing down before I go out on the high way. I then take about a 50 mile trip where the speed limits vary from 40 to interstate speed. Once the computer has completed the relearning it will idle and drive smoother for you. Hope this helps.
Dec 09, 2015 | 2003 Kia Sorento
Speed/Acceleration Button Doesn't Respond
are 2 solution, try to replace the acceleration button, or membrane for to fix it. 2) replace the complete Console.
You can call to the service support and ask for the membrane for to replace, or see if your operator manual for the part number.
Blessing
cuadra2016@yandex.com
whatsApp:+50588611441
Nov 01, 2017 | Precor 933 Premium Series Treadmill
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
Hoe to know the speed of the internet when it is connected to computer???
You can test your internet connection speed by using the Scanmyspeed.com .It provides you the accurate results ..
Apr 05, 2011 | Computers & Internet
My ProForm 750 only runs at low speed. Varying
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
Good luck.
Jul 25, 2010 | Proform iLog 750 Treadmill
I am trying to format my virus rdden computer, however when I get to the point of accepting the agreement with windows (after booting from the cd) it won't allow me to accept. what do I do?
Generally this occurs when F12 is pressed multiple times causing the keyboard to stop responding because the keyboard buffer is full.
At boot, when the Dell Splash Screen Appears press the F12 key once when the progress bar is 70% across the screen (System should beep ONCE) then select the optical drive and press spacebar when prompted. The keyboard should work fine after that.
Feb 25, 2010 | Microsoft Windows XP Home Edition
My dell keyboard responds slowly to key presses. sometimes not at all! it takes ages to type email!
I think I finally figured this thing out. On mine it only seemed to happen when I was online. I thought that maybe there was just too much happening at the same time. Well turns out that there may have been. I turned off the gadgets that are on my sidebar on my desktop and voila! Works like a charm. Hope this helps
Oct 03, 2009 | Dell 0Y3740 Keyboard
My computer operates very slowly and erraticly , sometimes at normal speed and sometimes very slowly, and even not responding at all for a few minutes. I have a Dell 9100 Inspiron with Microsoft XP Home...
To defrag your hard drive go to , start menu --> all programs --> accessories --> system tools --> disk defragment --> then select your hard drive and click defragment. This can take a few hours depending on how big your hard drive is and how much stuff you got. This may not even speed up your system. if your computer is running slow go to task manager and go to the proccesses tab and check if there is any unnessesary proccess running, if so just end them. write down the name of it and then delete it from your computer if you dont need it. :) hope that works. :)
Jan 22, 2009 | Apple MacBook Pro Laptop Computer with...
My computer is really slow and frequently crashing (program not responding). The internet takes ages to load and although just 2 and a bit years old it has been like this for most of the time. I'm...
try to get anti viru and scan it after dat try to get noadware software use that one too to scan adware after that reboot your system it will be faster
Jul 26, 2008 | ASUS Computers & Internet
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
16 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
