Question about Acer Aspire One PC Notebook
Hi I have an ACER Aspire M and Battery will not charge while it is running
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to stop work for it to charge. How can I fix this problem?
Hibernate the computer and start it again. It will charge normally.
Posted on Jul 30, 2013
  • Claudio Rossi Jul 30, 2013
  • Lisa Rosenbaum
    Lisa Rosenbaum Aug 30, 2014
    wow - that worked - why is this an issue with the Acer Aspire M?
  • 156 Answers
Check the DC power jack see is not the issue.
Posted on Sep 23, 2013
romsky79
  • 822 Answers
SOURCE: acer aspire 3680 laptop will not charge while plugged in wall
check your charger and dc jack.
Posted on May 31, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
leecom72
  • 4806 Answers
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Posted on Sep 08, 2009
deanot26508
  • 77 Answers
SOURCE: Battery will not charge on netbook
Sounds like it may be an internal problem with the charge system on the laptop, if you can run the laptop with the AC cord but it will not charge, I suspect the charge module is bad.
May have to return it for repair.
Posted on Sep 10, 2009
Testimonial: "I took the battery out and put it back in and it says charging but doesn't. I am going to reset the machine to original settings to see if it works."
  • 3 Answers
SOURCE: Acer aspire one AOA110 wont charge either battery (3 and 6cell)
if your Acer laptop battery or adapter need to be replaced?
Posted on Nov 09, 2009
I'm using a "ACER aspire
There should not be a problem provided the notebook is used with the battery on occasions and charged up again when the battery level drops to approx. 25% level.
Jun 15, 2011 | Acer Aspire 5742Z-4200 Notebook
My Acer Aspire 5600 has periodic charging problem. Will charge up OK when switched off. When switched on, after a while the battery indicator changes from green to amber and then starts flashing. Then the...
I guess your charger has very low power (low wattage). That is why it charges the battery when the laptop is off. But as soon as the laptop is on, the charger can't keep up with the power dreained by keeping the laptop on and eventually the battery runs outr of juice.
According to the user's manual (http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5600_3680_UG.pdf)
I suggest you get a charger with at least 90 W.
Mar 25, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Acer Aspire 4720Z Battery works till about 32% and then it gives a low battery warning of 5% before shutting down. It wont restart unless its plugged in. The battery shows 5% charge remaining. Where has...
Laptop battery notification is not accurate but approximate. The remaining battery usage is calculated approximately and then notified to the user. If your battery's life is more than a year, then the calculation goes on decreasing. It cannot be rectified unless you go for a new battery. But still you can tweak the battery life by,
1. Switch of the wireless adaptor when not in use.
2. Decrease the screen brightness.
3. Configure your power plan in control panel to minimal power usage mode while on battery.
4. The notification limit for battery low can be custom configured in the control panel. set it to 30 % and this will prevent your laptop to dye without power as your battery power drains faster below 31%
I hope this is helpful to understand the logic behind this.
Sep 11, 2009 | Acer Aspire 4720 Notebook
I have an Acer Aspire one model zg5- Power cord
Here is another thing you can try. Unplug the power cord, and then remove the battery. Press the "Start" button and hold for 5 seconds. Replace the battery back into the computer and plug in the power cord. Start the machine and see if the low battery message still comes up. Sometimes the program that monitors the battery status gets confused. Doing the above should straighten it out. The Acer should start up and the AC power light should be lit. Look down in your task bar for the battery Icon or go to Battery Status in Control Panel and see if it shows that the battery is charging. Even newer batteries can go bad (rare) but if this is the case and a cell has shorted out in the battery, then your only recourse is exchange under warranty.
Jul 16, 2009 | Acer Aspire One PC Notebook
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Acer aspire 3000 doesn't charge
are you sure the battery is good? How old is the system and battery? Do you have any way to check voltage at the battery terminals?
Aug 29, 2007 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
1,177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
