Question about Autometer Science & Laboratory
Fuel tank popping noise
Confirmed popping noise from fuel tank shortly after start up and then again shortly after shut down. It is not in the exhaust system. Is there some type of fuel vent/valve that is either plugged or defective. It acts like the tank is unable to equalize the pressure. As if the fuel when sucked out the tank basically is collapsing in (Popping in noise) Then once the fuel pump stops after shut down the tank pops back out as air must leak back in? I have tried to find a diagram to find if there is such a component, and if so where is it located?
    Master:
  • 347 Answers
Does it do it if the cap is off?
Posted on May 02, 2017
Testimonial: "I don't know....didn't try that but the issue went away sometime ago on its own."
I have the battery light on, and a banging noise in the gas tank. Could this be the fuel filter in the tank or the alternator?
it sounds to me that your fuel pump is going out and if your battery light is going on then you might check the battery by disconnecting battery while engine running if it dies then your then your alternator is shot if not then you might have battery checked out
Dec 10, 2015 | 2002 Hyundai - Sonata
Chevy s10 '98 metal popping sound from fuel tank after engine shut off.
Sounds like the catylitic, I wish I could spell, converter may be clogged or starting to clog. If you have the test equit. to test the exhaust output this will help, but since Idon't know anyone that has that type of thing just laying around, go to a muffler shop and see if they will assist you in solving your problem. They will usually check it out at n/c. Be Safe and HAGO!
Dec 05, 2013 | Chevrolet S 10 Cars & Trucks
Metal popping sound from fuel tank, after the engine has been shut off.
Check your fuel filler cap has an air vent that is not blocked.
Dec 05, 2013 | Computers & Internet
1990 Aerostar runs and after a short time sputters and shuts off.After sitting awhile starts and does same thing again.Fuel in tank,converter changed,fuel from filter ok.What else could it be?
You would need to treat it like a no start issue when it stops running.
Check for spark at the plugs and fuel pressure at the injectors.
Could be the EEC relay or other electrical component.
Aug 25, 2012 | Ford Aerostar Cars & Trucks
Our snapper shuts off after 15 or 20 minutes, does start back up after it cools - what do you think?
Could be the coil. Once it gets hot it shorts out and shuts the engine down then cools off and works again. OR it could be that the fuel cap doesn't vent and allow air into the gas tank causing a vacuum lock so fuel won't flow out of the tank. Just need to clean the fuel cap vent holes. Test for spark right away when it shuts down and still hot to find out if it is the coil. If the spark is gone when hot and normal when cold then it is the coil.
Oct 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
This car just shuts down while driving after it sets for a few min. it will start back and run good till it shuts down again
Hi,could be an "airlock" in the fuel tank, next time it does it open the filler and listen for any air thats rushing into the tank , if there is a suction noise the fuel tank breather could be blocked, good luck.
Feb 22, 2010 | 2001 Cadillac Catera
My 1986 2kr FZR250 won't kick
sounds like the fuel pump my freind its just under the fuel tank on the fzr,s near the back of the tank sounds like replacement pump will sort it hope his helps
Dec 16, 2009 | 1987 Yamaha FZR 250
1995 sarari van stalls. replaced fuel pump
SOUNDS LIKE FUEL STARVATION CHECK FUEL LINES / AND CARB.
Oct 22, 2009 | 1995 GMC Safari
My 1994 Mazda b3000 p/u died on me while i was driving. Has gas, new filter, and does crank but wont start. Need help
Does the electric fuel pump come on when you turn the key? It should make a buzzing noise for 3 seconds or so.
Jan 22, 2009 | Mazda B3000 Cars & Trucks
Science & Laboratory Logo
1,121 people viewed this question
Top Autometer Science & Laboratory Experts
William McMath
Tom Chichester
Are you an Autometer Science and Laboratory Expert? Answer questions, earn points and help others
