What button do i push to boot up - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
There should be a large button on the front of your desktop computer press it in
Posted on Jan 04, 2013
Will not boot up
Have you tried a System Restore/Recovery? Need more info? Compaq Model and the OS you are using. Unplug, remove battery, plug in, push on button, What happens when you push the on button?
May 19, 2013 | Compaq Computers & Internet
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
The phone turned off and will now not power back on
probably a battery issue, is it completely empty? connect you charger, it shoul boot up and show the battery loading image... push the power button again until it shuts off again, then push power button again (long enough to see it start up) than it shoul boot again... good luck
Feb 02, 2011 | Motorola Mobility Droid X
Push button is always stuck on the fan runs on high speed will not boot
yes will not boot because the power switch button is always contacting to switch. is like a long press about 3 or 5 seconds it can be turn off the system. remove the front cover clean the push button power switch housing and apply lubrication such as grease or oil.
Oct 11, 2009 | Everex GA3400 PC Desktop
Turn the computer on no matter which button i push
You may have a defective keyboard. A defective keyboard will stop the boot up process. Try another keyboard and see if that fixes your problem.
Oct 09, 2009 | Computers & Internet
Boot lid will not open except by use of key
Removed lock solenoid actuator and tested off vehicle, cleaned up terminals and pulled some fuses and relays cleaning wherever I thought necessary, also cleaned locking rod at filler cap with maintenance spray and lubricated mechanism inside boot underneath filler area. Both items now working but still not sure what the cause was.Suspect dirty terminals but these were not readily apparent
Dec 19, 2008 | 2001 Jaguar XJ8
Dell Inspiron 1000 will not boot up.
Greetings,
The symptoms you described are normally common motherboard failure signs.
Try removing the ram and hard drive from the computer and then try booting the computer.
Oct 28, 2008 | Dell Inspiron 1000 Notebook
Dell latitude D600 booting problem
Are all three lights on when you hit the power button?
Aug 25, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
