Question about Asrock K7S41GX Socket A SIS741GX FSB333 Motherboard
Turns off in a fraction of a second
My computer is about 3 years old, and has always worked fine, but after moving the computer won't stay on. When I hit the power button, it immediately turns off, staying on just long enough to get the fans spinning. I don't get any beeps. After I turn in on once, it won't turn back on for a while.
I thought it might be the CPU overheating, so I swapped it out along with the heat sink, but get the same problem. I've tried resetting all connections, strip out all extra components, but the problem persists.
  • 5,568 Answers
Probable power supply failure.
Posted on Jan 19, 2009
Need to reset pin
Dear,
Any board there 3 stander Jumper for BIOS Config 1-2-3 in normal condition jumper always will be short on 1-2 if you want to clear the BIOS Config switch the computer take out the Jumper from 1-2 and insert in 2-3 after that switch on for 5 second and turn off computer then again take back jumper in to old postion that is 1-2 then start computer go in to bios setup you can see bios will be clear all old setting,
Thanks with Regard,
Ankur Goyal
Sep 10, 2015 | Computers & Internet
When I turn on my computer the monitor turns on for about 3-5 seconds and then goes black. The blue light stays on and does not blink. If I turn the monitor off then back on it will again show the screen...
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust in its socket
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this help you
Aug 28, 2011 | Computers & Internet
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
No POST/Black Screen
Believe it or not, clearing the CMOS might actually help. Make sure you do it right by completely unplug the power cord or turn off the PSU, then take the battery out.
It also sounds like the CPU might be too hot. Look under the fan of the heatsink and see if there is any dust that will block the airflow. When the computer is on, touch the heatsink and feel if it is really warm. If it is really warm, it's a good sign, you might just need more airflow. If it is cold, you might need to reinstall the heatsink/apply new thermal compounds.
Mar 07, 2010 | Gigabyte Computers & Internet
I have checked monitor with work laptop and monitor works fine, issue started after replacing cpu fan on motherboard, had previous issue with old card, got no signal with old card rebooted computer and it...
I would check the video card to make sure it is seated properly and clear from any dust and lent in the slot.
Also, make sure the fan/heatsink is on properly. If your processor isn't staying cool, it will turn on for a few seconds then shut off.
Jan 13, 2010 | ASUS P4S800 Motherboard
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Computer won't shut down.
Dear Catobion,
its a OS related problem, please call some technical guy ,which can reload the Operating system again in your pc, and i'm sure it will be work fine and faster.
Be Happy always
Scorpion
Sep 15, 2008 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Asrock K7S41GX Socket A SIS741GX FSB333 Motherboard Logo
77 people viewed this question
Top Asrock Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Mark Taylor
Mark Taylor
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
