Question about Whirlpool RF378 Electric Kitchen Range
Locked door put in clean mode no will not open?
Locked door
  • 21 Answers
The door will remain locked until the temperature inside the oven drops to a safe level.
Posted on Jan 19, 2009
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Door won't close due to latch being in lock position from self clean mode, pulled to check door and latch activated while open. How to latch to move.
Have you tried put it back I clean mode it might reset it self.If work let it finish cleaning this time please.
Dec 18, 2014 | Kitchen Ranges
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
How can i unlock my oven kenmore
Hello,Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position.
If this doesn't work, you may have a failed door latch, control, temp sensor, or switch.
Thanks
Jun 03, 2010 | Kenmore 30169 Electric Single Oven
Oven door wont open
i was cleaning the oven when they a black out and when the light came on the oven whould not come on and the is still lock what can i do
Jun 01, 2010 | Kenmore 36665 / 36669 Gas Kitchen Range
On a kenmore 790 electric oven what does F9 error code mean and how can I reset it I put it in cleaning mode and it won't open the door even after cooldown
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Frigidaire oven model # 316244485. I
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@@#@#$
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door that wont come unlocked
sounds like you have a latch/lock issue. the unit seems to think the door is still currently locked, preventing proper operation, i would try to see if you can locate the door/light switch and manually trip it with your hand(turning off light). then while keeping depressed activate the self clean mode again, the machine will try to engage the lock/latch, as soon as it does then cancel it and it will return back to a normal resting location. you must keep the light switched pushed in order for this to work correctly
Oct 07, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool RF378 Electric Kitchen Range Logo
66 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
