Question about Uniden D3097 LOUD & CLEAR Cordless Phone - 1 x Phone Line - Answering Machine - Caller ID - Speakerphone 050633274309
Can recieve calls but can't call out also yellow flashing light on hand set wont go off
I want to know if this is going to be a frequent problem? How can it be avoided? We unplugged the unit and it seemed to work. This is a brand new phone and I want to know if it should be returned?
4 Suggested Answers
SOURCE: Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
Posted on May 07, 2008
SOURCE: base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Posted on Sep 30, 2008
  • 11 Answers
SOURCE: I purchased the phone last week. It was working
I have had many of these and this sounds like a dead battery.
Posted on Aug 25, 2011
My lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Jun 24, 2012 | LG 42LC2D 42 in. LCD HDTV
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I stopped recieving e-mail a few days ago I don't know why and don't no how to fix it I am computer illiterate
well at least youre honest and im not too sure if anybody here can help you because most email probs are caused by username or password problems and im sure you dont wanna hand those out. im sure if you ring your internet provider they will talk you through all the settings and all should be good. If they wont maybe you need to trust somebody like me and i have no interest in others emails so call me anytime ok i'll sort it out for you. cheers and plz vote
May 25, 2011 | Computers & Internet
BLURY PHOTOS YELLOW TRIANGLE HAND EXCLAIMATION WARNING SYMBOL
It indicates the shutter speed is too slow for you to hold it by hand without something like a tripod.
Either there's not enough light in the conditions you're taking the pictures in, or you need to try changing the settings on the camera, such as increasing the ISO setting, or light sensitivity, so it can use a faster shutter speed.
If it's close range, turn on the flash.
If you can't change the settings, you can try bracing your hand against a fixed object so that the camera doesn't move, and just gently squeeze the button to take the picture. Novices frequently jab the shutter release to take pictures, which will cause blurry pictures from the camera moving.
Dec 31, 2010 | Pentax Optio M30 Digital Camera
It wont turn on just flashed red light and wont give the disk back
watch the lights on the front when you try to turn it on. If the blue light flashes yellow for a second, you have ahardware failure, so-called Yellow Light of Death. You can get the disc out by turning off the switch at the back, then hold down the eject button and turn the back button on again.
May 01, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on. light turns green, flashes
This is known as the yellow light of death.(ylod) It's about 150 bucks to have it serviced unless it's still under warranty.It says in the manual it is an overheating issue.
As for your problem, call customer support at 1-800-345-SONY
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
I own a toshiba 62hmx85 tv and had a frequent humming sound coming from the tv, technicians told me over the phone that it could be the color wheel going, soon after that the tv stopped working and all i...
The color wheel on this set is not available. First thing I would do is replace the lamp. MCM electronics has a Philips for $99.00. The hum could have been the lamp fan which is common on these sets. There is a kit from Hitachi the includes some rubber dampers. What I commonly see on these sets is when the lighr engine is going bad(this is where the color wheel is) the color gets a green,bue or yellow tint and trhe picture may get dim. its rare that the color wheel stops working on this model. Call adifferent tech for sevice. Anyone with experience on these sets will know whats up.
Dec 03, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
YELLOW LIGHT????????
You have the "yellow light of death". Your system needs to be repaired. There are no work arounds or home remedy you can use that will fix the console. Call Sony customer support.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Wont recieve calls! razr v3
You may have the profile set on silent with no vibe. alert. Go into settigs, profiles, choose customise and set to a higher volume.
Jun 07, 2009 | Motorola Mobility RAZR V3
Uniden D3097 LOUD & CLEAR Cordless Phone - 1 x Phone Line - Answering Machine - Caller ID - Speakerphone 050633274309 Logo
16 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
