Question about Vizio L32 32 in. LCD HDTV
Cable adapter on tv broke off
My picture was fuzzy so I played around with the cable. The adapter piece from the tv snapped off. Is there another place on my tv where I can hook up my cable or does it have to be repaired?
  • 691 Answers
What type of connector is it? screw on? it will need to be repaired. A Cheaper option than some repairs is to buy a decoder box connect the cable to that then use the output from that to your tv scart/hdmi/component etc
Posted on Jan 04, 2013
Fuzzy picture
Try moving the hdmi cable around, disconnect it and reconnect it. Try using a different video source.
Oct 20, 2012 | Hannspree Televison & Video
Picture gets fuzzy especially the writting on 2000 Sansui tv
This could be multiple things. If the fuzzy picture is on your regular cable channels and the tv is hooked up directly to the cable then it is a signal issue. Your cable signal is probably too low because it is either split too many times, a splitter went bad, a piece of cable went bad, you have RG-59 cable rather than the much better RG-6 cable. Another solution is if there is a vcr hooked up, the cable jack on the vcr could have gone bad, the vcr power could be on which will cause a fuzzy screen. If you have a vcr try to bypass it and hook directly to tv. If that fixes you problem then it may be the vcr or the wire from the vcr to the tv. If you have no vcr then I recommend buying a cable amplifier and hooking it up. This is a band-aid solution but it could work long term if it's just a matter of weak signal. If that does not fix your problem I would recommend calling a cable professional to evaluate your problem. Could be the line from the pole to your house or any of the wiring in your home.
Jul 10, 2010 | Panasonic CT-32SL15 32" TV
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
TV is fuzzy and not showing a clear picture
  1. If your set is connected to a cable TV box via coax cable check the connection on the cable box (both Input and out to TV connections) tighten if necessary.
  2. If your using a cable splitter to split the cable to multiple TVs check those connections also.
  3. If this fails to correct the problem you may have a bad cable which your cable provider should replace at no charge to you.
Dec 17, 2009 | Dell Televison & Video
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
The picture is fuzzy on that cable box.
try this......
1. if u can manually tune the channel, and then fine tuning it....
2. if that doesnt work, go to menu, picture menu and decrease the sharpness to somewhere around zero.....
tellme what happens...
Jun 29, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Picture problems
check the inside of the PS2 or make sure the TV is ok or call sony up and use your warranty you should be able to
Jan 31, 2008 | Sony PlayStation 2 (PS2) Console
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Vizio L32 32 in. LCD HDTV Logo
190 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
