Question about Uniden D3097-4 D3097-4
Cannot make calls
Can receive calls but can't dial out.....flashing yellow light
    Sergeant:
  • 475 Answers
Did you try a different phone jack? Or does your phone take batteries they might be low, or try to contact the company through e-mail.
Posted on Jan 04, 2013
Flashing lights on nortel t7316e phone
ld 20
req:prt
Type:phone Type
Dn:Particular DN
enter
enter
Req:enlu Tn
req:stat tn
Mar 31, 2013 | Nortel Norstar 16-Line PBX Speakerphone
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
Mar 19, 2013 | Nokia XpressMusic 5800
How do I reset the message indicator light?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 18, 2012 | GE Rca 25414re3-a Executive Series 4 Lines...
Yellow flashing light on screen
It is Progressive Scan mode
if you don't want it then follow this
  • Press the "Menu" button. Turn the control dial and select "M."
  • 2
    Rotate the control dial and select "Prog. Scan." Press the control dial.
  • 3
    Rotate the control dial and select "Off." Press the control dial. The Progressive Scan LED light should go off.
    Performance Chip
May 23, 2012 | Sony Video Cameras
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • Jun 30, 2011 | Vtech Cordless 6041 Phone
    I receive a call from outside, press flash and dial the extension but it the person to whom I direct the call can not get the call and if I try to return to the call, it is disconnected.
    The FLASH button is for outside calls. Try the TRANSFER button. If the inside party doesn't answer, press the outside line button that's flashing green. If you have a Panasonic brand voice mail, you can also transfer the call to voice mail with another button.
    Carl
    Apr 13, 2011 | Panasonic KX-T7730 Corded Phone
    Cannot receive calls and dial tone flashing
    You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
    Feb 26, 2009 | Mitel 5220 IP Phone
    Uniden D3097-4 D3097-4 Logo
    62 people viewed this question
    Top Uniden Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you an Uniden Health and Beauty Expert? Answer questions, earn points and help others
