Question about Technics Audio Players & Recorders
The input selector switch has a mind of its own and changes when it likes to what it likes. There is a clicking relay sound when it occurs. Is this a faulty relay or a dirty switch. (Sorry about previ
SU-C1000
  • 3 Answers
I havd the same issue. u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Posted on Mar 09, 2013
3 Suggested Answers
jango2
  • 38 Answers
SOURCE: Yamaha DSP A-1000 input selector switch not working properly
i did not post that....and why would fixya be asking the poster of a problem for a solution?????
Bug? Pls delete these posts moderator.
ty
Posted on Mar 10, 2008
  • 236 Answers
flying yeti.... yup... it's definitely your input switch. im from yamaha service before at saudi arabia. that is a normal trouble specially in high humidity places. you can only get a replacement at yamaha service though. their newer model are better they dont use contact switches nomore.
Posted on Mar 18, 2008
I changed the battery and now there's a clicking noise and the A/C doesn't work?
Check the fuse and or change the relay switch that it clicking or turn the a/c on to full auto and gently tap the relay that is clicking. If it kicks in it will only be until you switch it off but then it will need doing again. Or just change out the relay.
Jun 23, 2014 | 2005 Ford Freestyle
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
Blower motor relay make clicking sound when i turn the heater on. Changed relay and still does the same thing
Sounds like your blower motor may have either ceased, or gotten an obstruction. Sometimes an animal will crawl into your heating unit and make a nest or other things get in there and bind up the hamster wheel (fan). Start by checking for power at the fan using a test light with a wire probe end. If you have power at the fan with the switch on but it's not spinning, first check for an obstruction, if no obstruction, check to make sure the ground is good from the motor (make your own ground with the test light by probing the ground) if the motor spins up, fix the ground wire, if not, time for a new blower motor unfortunately.
Nov 13, 2013 | 2005 Chevrolet Aveo
The imput selector on my technics su-c800um2 stereo controller behaves erratically
This is due to a possible fault in the digital logic switcher which is at the input selection and could be a failure of the logic gate or a fault in the subprocessor IC.
You can remove and clean the amplifer if there is noticable dirt , also check for DRY SOLDER or faulty connector or joints if a TAP bring this fault up.
Jul 02, 2012 | Technics Audio Players & Recorders
No Sound from Receiver
The relay is suppose to click because its whats sending the signal to switch modes.Check on the board for blown fuses.
Mar 29, 2009 | Audio Players & Recorders
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
ty
Mar 09, 2008 | Audio Players & Recorders
Sherwood AI5010 no sound from either channel
Hi There DEKCAT
Its very unusual for both channels to blow......
I suspect that there is a blown power fuse inside the case......
There are fuses sometime located on the outside rear of the case and these can be easily checked to determine if they are blown..If you find one is blown please replace with the corrrect rated fuse,..... its current rating wil be on a small label on the case outside rear. like 1.0amp, or 1.5amp etc...
If you need to go inside the case please ensure the power plug is removed from the wall socket first.
You will find small glass fuses in the DC power supply feeds and probably one of these has blown, once again replace with the correct rated fuse.
Im not sure if your amplifier is a FET type or a large 32-40 pin IC type as if these are blown you will need a service person to do the replacement...
Please note there is a small relay that clicks 20seconds after turn on at the switch....if this click is not happening then there is problems with the timer circuit or the relay itself...
This relay controls the output to the speakers and as such stops all the sound output if its not working...so the first thing is to check all fuses, if they are OK then check the Relay operations....
Cheers From YUBEUT
Nov 09, 2007 | Audio Players & Recorders
Emerson AV101 System no sound
it could be one of two things.... the first is that the speaker selector is set to OFF. the other thing (also the more expensive one) is that there is a problem with the amp, and you either have a problem with the offset voltage on the output of the amp, or that the idle current in one of the output stages is too high. normally, a protection circuit monitors the output stages for these two faults, and if there's no problem, your speaker relay clicks in within 30 seconds of turning on the power. if there's a problem, the relay never clicks in. so first check your speaker selector. if it's done by "soft switching" (not a physical selector switch, but a microprocessor controlled relay) then you also could have a problem with the processor chip, or with the parameter storage memory (which sometimes uses a backup battery). sometimes the backup battery isn't a battery at all, but a very large (electrically, not physically) capacitor that keeps alive the parameter RAM. if the power is left off for more than 2 or 3 days, the capacitor will lose it's charge, and the stereo "loses it's mind". same thing if it's a dead backup battery. sometimes if the battery is marginal, you lose some settings, but not others or the settings get changed
Jun 24, 2006 | Emerson AV101 System
352 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
