Question about Coleman 1997 Fleetwood Sunridge Refrigerator Vent Door Cover Pop Up Camper
How do I fix seal on camper? - Coleman 1997 Fleetwood Sunridge Refrigerator Vent Door Cover Pop Up Camper
Pump works no water
Thetford makes good pumps. No pumps last forever, actually only 4 to 5 years of constant use because the pump sucks air at first startup before pumping fluid. Air ruins the pump. The pump also collects sand (small tiny particles) which act like sandpaper and ruins the shaft, and impeller, etc. It's cheaper to buy another pump than to fix it, because more importantly you won't find parts to fix pumps. whether RV pumps, or Fountain pumps - the reason is the pumps require to be sealed - factory seal. So no one will carry parts.
May 10, 2014 | Thetford 33368 Cassette Toilet Pump Camper...
We bouhgt a 1979 solid shell camper, and we need to find out if those came equipped with electric brakes
Most of them did but you can find out by removing the wheel while the camper is on jack stands and seeing if the hub is removable or sealed bearing. If it's is removable then you can visible inspect them. You can also trace the wiring to lights and turn signals and see if there are wires going to wheels.Hope this helps. Thank you
Mar 30, 2011 | Garden
Do pop up campers have batteries for their electrical system?
YES MOST DO TO RUN LIGHTS. YOU NEED TO SNOOP AROUND YOUR CAMPER TO SEE IF IT HAS A PLACE FOR A BATTERY. SHOULD BE ON THE OUTSIDE OF THE CAMPER.. NOT GOOD TO HAVE IT INSIDE OF CAMPER UNLESS IT A SEALED BATTERY, BATTERY'S LIKE A CAR BATTER GIVE OF HYDROGEN GAS AND CAN EXPLODE VIOLENTLY SO IF YOU ARE THINKING ABOUT ADDNG A BATTERY PUT IT ON THE FRONT HITCH ASSEMBLY AND USE A FUSE THAT MATCH THE SIZE WIRE AND LOAD.. YOUR LOCAL AUTO PARTS STORE CAN HELP YOU WITH ALL THE THINGS NEEDED RIGHT DOWN TO THE 12V FLOAT CHARGER OR MAYBE EVEN SOLAR ! GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 27, 2010 | Electronics - Others
Refrig in camper keeps freezing food even when on lowest temp
It's either the thermostat or the door seals leaking Since its freezing the refridgeration unit is fine
Oct 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Water leak in travel lite truck camper has caused over cab bed area plywood to decay. Need diagram or schematic to determine best method of repair.
Hi brad, I had the same problem with a camper. I do not know of any available schematic, but would recommend dis-assembly of ceiling area to fix. It's not any easy job, but the only way to fix it properly. Remove all water damage section, make sure water is not pooling on the exterior roof. If it is collecting on the roof, you must brace it from underneath to raise any 'dips' so it sheds water, and make sure you apply a sealing coat (available at trailer stores, or on line) on the exterior. Also, if you park the camper when not in use, make sure you tilt it to help shed water more quickly. You have to use your carpenter and auto body skills to fix this. Don't put it off, I did and the roof deteriorates very quickly once you notice you have a problem. To remove plywood that is damaged, use a skill saw set at the minimum depth (thickness of the plywood) so you don't cut thru anything else. Use a drill to determine the thickness. To install new plywood, cut to fit the opening(s). Next get 3" wide by 3/4" thickness boards, place above cut out area, half on existing ceiling, half hanging over cut out, screw in thru existing ceiling into boards, attach replacement piece, screw into overhanging boards. You can putty over the joints, sand sand and paint, or just glue some sort of fabric to cover the area and make it look finished. Good luck!
Sep 14, 2009 | 1999 Chevrolet C2500
Water damage in ceiling, plywood warped, contact paper bubbling u
Seal roof seams. set up camper . prop peice of plywood slightly bigger than damaged area under damageshim to acheive moderate pressure. wait a week & remove. If it comes back down will have to replace paneling.
Jul 25, 2009 | Coleman Campers Grill
The air conditioner on my pop up camper is loud and vibrating
sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
May 31, 2009 | Coleman Campers Grill
Roof leak 1999 jayco eagle mod 8333-8715
It is best to get self tapping screws and relocate them. The water leak has destroyed the wood where the factory screws were and a bigger screw will not work. Just move them over a few inches. If the leak was bad enough all of the wood will be routed and should be replaced. Is this on the top seam where the rubber meets the aluminum or is it on the side of the camper near the top?
Mar 24, 2009 | Sport & Outdoor - Others
Camper hand pumper operation?
Sounds like the seals or checkvalve is worn out.You could try primbing it but is sat for a long time, correct?
Mar 17, 2009 | Plumbing
Rear brake ceasing
cylinder is stuck in caliper strip and renew the seal and clean out the groove in the piston where the seal sits
Oct 31, 2008 | 1986 Volkswagen Wagon Camper
Coleman 1997 Fleetwood Sunridge Refrigerator Vent Door Cover Pop Up Camper Logo
66 people viewed this question
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
