Question about Conair Cuisinart SmartPower Compact Portable Blending/Chopping System
Blender won't turn on cuisinart smart power compact blender
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
I have the cuisinart SPB-7 Smart Power and it leaks. I put my milk in and it run on the counter top. What do I need to replace? Is it the washer?
The bottom part that screws on the jug with the blades, either the o-ring is bad,or the screw on piece is cracked and needs to be replaced.
Mar 17, 2011 | Cuisinart SPB-7 SmartPower Work Top...
I need the replacement glass bowl. My wife dropped and broke. It is the blender bowl for the Cuisinart Smart Power Duet, model FPB-5CH
Hi!!
Smart & Final carries a variety of glass bowls in plastic, glass and metal, at the cost or the S&H you would pay if ordering from dealer.
If helpful, click below.
Apr 08, 2010 | Juicelady JL600 Professional Work Top...
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
I have a 7-speed, Smart Power Cuisinart Blender
plz cont - 23051554 \ 23095757
Jul 21, 2008 | Blenders
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Conair Cuisinart SmartPower Compact Portable Blending/Chopping System Logo
Top Conair Blenders Experts
eyecam
Are you a Conair Blender Expert? Answer questions, earn points and help others
