Question about LG 47LH30 47 in. LCD HDTV
Hdmi imputs don't work
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Mar 27, 2015 | Sharp 52"" aquos lc-52sb55u 1080p...
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
Hdmi ports not working
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
5 Hdmi ports
Port one, cable box
port two, blue ray player
port three, Boxee box
port four, XBox 360
For example
Aug 07, 2012 | Hitachi 55HDT79 55 in. Plasma HDTV
When i plug in hdmi cable to the wd52525 there is no hdmi imput on the device page. can't get it to work
If it is not there or grayed out you may have to try the soft reset first--set also has a hard one but only to be used as last resort.
Soft one: set on, menu,1,2,3 enter.
Jun 08, 2012 | Mitsubishi WD-52525 52" Rear Projection...
How do I program hdmi imputs on a txsr 506
You don't program hdmi. The manual describes all that stuff and the unnamed product at the other end of the cable plays a part, too.
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
Sep 06, 2011 | Onkyo Audio Players & Recorders
I cant seem to figure out what kind of video card upgrade to get for my desktop that has an hdmi imput
I don't know of any video card that has a HDMI input. There are several that have HDMI outputs, but none are AGP cards, this is the older model.
But the HDMI can be easily obtained with an DVI to HDMI adaptor like
http://www.amazon.com/Cables-Unlimited-PCM-2296-06-HDMI-Cable/dp/B0007MWE1E
that can be plugged in every card that has an DVI output like
http://www.amazon.com/MSI-Radeon-PCI-Express-Graphics-MD512H/dp/B002EECNPA/ref=sr_1_14?s=electronics&ie=UTF8&qid=1307599951&sr=1-14
Jun 08, 2011 | HP Compaq Presario SR1550NX (PY059AA) PC...
Onkyo TX-SR805 Amp isnt projecting the picture through my Sony kdl46xbr. i am recieving sound but no picture. Reconnecting direct from source to TV and no issue so the problem is with the amp. HDMI symbol...
I have a 607 by Onkyo and you have to assign imputs to the imput selector. I don't know if your model uses the same, but if it does press setup and select input assign then select HDMI imput to see what it is set to.
Mar 06, 2011 | Onkyo Audio Players & Recorders
Imput problems with Samsung DLP TV
The parts required for this are available but difficult to find. The overall repair is not that difficult for anyone that has fixed these before. You'll spend more time getting to the jack than replacing it. Try calling Samsung parts and give them the model as well as the circuit designation of the jack. This designation will be written on the PC board. For less than $5 you should be able to get the jack. Ask a local service shop to install for you and you are off and running.
Dan
Aug 12, 2009 | Samsung DLP HL-P5663W 56" TV
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG 47LH30 47 in. LCD HDTV Logo
26 people viewed this question
