Question about Frigidaire FRS26R4C Side by Side Refrigerator
Frigidaire Side by Side FRS26R4CB3 - noise
Just started making a louder than normal noise. The section between the two doors seems to be getting pretty warm. Condensor? Fan? how to tell?
  • bxchapm Jan 19, 2009
    Thanks, tborn6. Pulled it out, cleaned and discovered the plastic fan blades had all been broken off. Probably been operating with only one of the baldes for a while.Will now replace the Fan.
  • 700 Answers
Pull the refrigerastor out and take the panel off that's on the bottom off the refrigerator in the back. Becareful because thats where the fan should be working and taking the heat away from the insides. If the compressor is on then the fan should be to. Also look underneath the unit and if all that you see is full of dirt then you'l have to clean it with a shop-vac and a long brush. Good luck and if you have another question please feel free to ask.
Posted on Jan 19, 2009
  • Todd Born
    Todd Born Jan 19, 2009
    good for you that was a easy one anfd thanks for the fixya
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Door Make Noise When Open and Closing.
If it is a squeak, you can lubricate the door hinges. If it is some other noise you will need to describe it.
Aug 18, 2011 | Frigidaire FRS3R5EMB Side by Side...
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
My fridge is making a god awful noise... it's still cooling, but the noise is off and on and each time it comes back it's louder and louder.... any suggestions??
When do you hear the noise? What is the refrigerator doing when the noise comes back?
If it is when the compressor kicks on, I would check the mounting brackets for the compressor and make sure they are tight.
If it is a clatter then I would check the colling fans (top and bottom and make sure the blades are striking something.
Where you say it is getting louder and louder, I would check for ice buildup on the evaporator fan in the freezer section.
Jun 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
Fridge making burbling noises
This could be two things, i have had fridges get louder with age, its the refrigerant returning to the compressor after condensing, but it could also be because its low on refrigerant. If the fridge is cooling normally and not having an issue getting cold then i would just leave it alone until it has further issues. Most places don't service them anymore, if your really really lucky you might find an appliance repair place that can send a tech out to check the refrigerant on the fridge, but the rule of thumb unfortunately is they are a sealed system, and if they get low its because they have a leak, and the leak is usually due to seals wearing out in the compressor, and a new compressor costs more then a new fridge!
Jan 11, 2018 | Frigidaire FRT17G4B Top Freezer...
Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Apr 08, 2009 | Frigidaire FRS26R4A Side by Side...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
Nov 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS26R4C Side by Side Refrigerator Logo
134 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
