Question about Saws
Where can I find discontinued parts for craftman bandsaw
I need a new sleeve bearing for the drive wheel p/n 977053-001
    Sergeant:
  • 475 Answers
Call the manufactor and see if they have left over parts or maybe a store near you. Or maybe you can e-mail the company and see what they say.
Posted on Jan 04, 2013
efs_perpends
  • 1996 Answers
SOURCE: I need a bandsaw blade for a Craftman 3 12 ( vint.
You'll need to find out the length of the blade in inches. If you have an old broken one, you can simply measure it. Then if you search online, you'll find a variety of sources that will weld/braze a custom length blade for you. (link here)
Otherwise, you might find a manual here. that gives the standard length for that machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Posted on Jan 21, 2010
  • 4088 Answers
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Posted on Jun 25, 2010
puertobori
  • 7733 Answers
SOURCE: I have a Delta BS220LS Bandsaw. The tire part no.
Give a try here -> eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Oct 15, 2010
ToolBoxHero
  • 171 Answers
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams.  You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
Posted on Jan 06, 2011
Bandsaw lower wheel bearing replacement procedure
Since the bearings are bad, you don\'t care about hurting them worse; your three priorities are (1) getting the bearings OUT, (2) not damaging the wheel, and (3) not hurting yourself in the process.
The single best way I know to accomplish what you\'re setting out to accomplish is to use a small slide hammer with two fingers barely small enough to fit through the bearing\'s center hole. They\'ll hook on the insides of the inner bearing race. As you tap on the hammer end of the tool, it\'ll tug the bearing right out.
The second best way I know to do it is to use a long pin punch - about a 1/4" should be fine for it - and about a 120z hammer. You reach through one bearing to tap (GENTLY) on the inner race of the opposite bearing. Work ALL THE WAY AROUND so you don\'t accidentally cock the bearing in its bore as you drive it out. If you can detect that it\'s cocked a little, drive a little more on the diagonally opposite side until it straightens. If you cock the bearing in its bore, your wheel will be wrecked.
As an alternative to the pin punch, you can also drive out a bearing by using a concrete nail (available at your hardware store) turned around backwards. Concrete nails are stiffer, tougher, and harder than ordinary lumber nails. You\'d reach through one bearing\'s inner race with the HEAD of the concrete nail and tap on the nail\'s pointed TIP with your hammer. The nail\'s head will give you a straighter driving angle than the pin punch will. Still, use exactly the same procedure - tap gently and work all the way around.
Once you get one bearing out - either way, slide hammer or pin punch, you can easily drive the other bearing out. For that, you\'d use a deep socket barely small enough to fit through the hole in the wheel, plenty big enough to catch as much of the bearing\'s outer race as possible. Again, tap GENTLY on the opposite end of the socket with your hammer, and watch carefully - if that bearing cocks a little, you have to concentrate on driving the diametrically opposite side a little more so the bearing drives straight out.
If this wasn\'t for a bandsaw, I\'d recommend heating the wheel\'s hub (BUT NOT the bearing!) with a propane torch to expand the aluminum hub a little - the bearing would nearly fall out - but this IS for a bandsaw, and of all things you don\'t want the heat to to distort that wheel. Careless torch work can even melt the wheel, and it\'d certainly ruin your tire. The carpet, too. :) :) :)
No, leave the torch alone, don\'t use it here. If you\'d like to own a slide hammer, find a SMALL one & buy one. If you\'d have no later uses for a slide hammer, try working with either a concrete nail or a pin punch.
Mar 14, 2014 | Craftsman 12 Tilt Head Band Saw Owner...
REMOVEING DIFFERENTIAL ON A 1999 300M FRONT WHEEL DRIVE
The diff is part of the trans axle automatic transmission assembly and is not a separate part that can be removed.
Oct 10, 2012 | Cars & Trucks
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
7. close the covers
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
2002 f250 4wd, 7.3 psd. noticed today while
the wheel bearing is the cause, it has a support bearing that hold the axle in place.
Oct 04, 2009 | 2002 Ford F250 Super Duty SuperCab
Clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Sep 23, 2009 | Grizzly Saws
Need drive wheel for craftsman bandsaw
Here is your link to craftman's parts. They can get parts for just about any make or model.
SearsPartsDirect.com
Mar 26, 2009 | Craftsman Saws
Craftman wheel flange bearings
Use a long punch and tap out the bearings from the opposite side, through the hub. Then tap the new bearings into place.
Dec 23, 2008 | Garden
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
