Question about CDA Washing Machines
CDA CI330 Washing Machine Fault F06 Not Heating?
Fault code F06 (code = failed to heat) I have tested the element resistance and have a reading of 28 ohms and nothing to earth unfortunately I don't have an insulation testers so can't test for insulation. Any ideas?
  • Robert Chamley Jan 05, 2013
    Just looked at the thermostat and found a build up of fluff. Cleaned the stat and testosterone resistance in hot and cold water. Resistance goes down when hot water applied. The over temp cut out had activated but able to reset it. Once re built I now get a F05 fault . Any ideas?
  • Robert Chamley Jan 10, 2013
    Just replaced the NTC thermostat and alls good again :-)
  • 236 Answers
SOURCE: heating element
you have to remove the back half of the case by removing the lid, screws at the sides (bottom) and from the bottom rear. then from the top centre. slide the rear case backwards by seperating the hose bracket and the element is at the bottom of the outer tub.
Posted on Jun 11, 2007
Oceti
  • 51 Answers
SOURCE: dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Posted on Dec 17, 2007
jsrock516
  • 5911 Answers
SOURCE: F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool LER5636EZ3 dryer won't heat
hi If it reads 0 hms yes thats te problem Thanks the appliance doc
Posted on Sep 12, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
My LG has an ie error that persists even when the valves and inlets have been checked, the machine shuts down while filling with wate. Had the machine less than 3 years, how do I fix this?
it could be the heating element, if the heating element is damaged the pcb will cut the power. as its detected a fault. the element has a resistance if it goes up or down in resistance the pcb detects this as a fault. you can test this by removing the wire to the heater element, it will fill up with water then but when it comes to heating water it will shut of as a fault. and show a code.
Jun 26, 2017 | LG Washing Machines
Miele t224 is not heating and suspect it's the thermostat. I have tested one with the multi meter and no reading.i understand there are others !can you direct me to it or them please ? So I can test
Make sure the wires are not connected during tests. At room temperature, you should get a reading of zero on the thermostat. When heated, it should read infinity.
You can also test your heating element. Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jun 13, 2016 | Dryers
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Frigidaire Affinity error code 68
Hello - Typically error code E68 can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exist, the electronic control will need to be replaced. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, replace the heating element.
Jan 10, 2013 | Frigidaire Washing Machines
TE code wm2688hnm
proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
Aug 03, 2012 | LG WM2688HWM TROMM SteamWasher
Cda 497/1 not washing
see this possible causes: Water-heating cycle the cicles compren washing, and rinse, the machine stop, because the heating element, and thermostat can be defective test.see the diagram Timer test the timer see the diagram for defective, clean contact, with special spray, tigh the wires very well. 5_9_2012_10_57_35_am.gif5_9_2012_10_57_57_am.gif
May 08, 2012 | Dishwashers
I have a Zanussi W/M ZWF1640 showing E34 fault codes in diagnostics mone. any clues?
Three things i would suggest on the zannuzi. Does water come into the drum at the beginning of the wash? Does the drum turn if asked to wash or spin? Does the drain motor disperse the water in the drum when supposed to. If motor does not turn, check the brushes. Sorry for being so vague, Zannuzi not common in S.Africa, but those are the common problems i have found while repairing the odd one.
Aug 03, 2010 | Washing Machines
Washing machine fills up and starts the wash cycle and then displays an F05 error.
F05 error code means heating circuit failure.The water temperature sensor is not working. It might be just disconnected or unplugged due to vibrations over time.Unplug the washer and open the housing. The sensor is located at the base of the wash tub in front of the heating element. It is square -shaped connected between the heating element terminals.Clean the terminal leads before reinserting.
If the sensor is well connected between the heating elements and the washer still not work, disconnect the heating elements and check the resistance. The resistance reading should be at around 9K ohms at room temperature, else replace.
Aug 06, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
43 people viewed this question
Top CDA Washing Machines Experts
noel
noel
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
