Question about HP LaserJet 3015 All-In-One Printer
I am getting a black streak (1/4")down the left edge of the paper
I have been using this printer for about 3 years and just now started getting a black streak, about 1/4" wide down the left side of the paper, the full 11' length.
  • FASTLEARNING Jan 22, 2009
    I now get a "Upgrade Error" "Call HP Support"
  • HP Master
  • 19,396 Answers
Regarding the bleak streak, that is dirt inside the printer , the printer need to be cleaned inside.
Regarding the upgrade error , when that happen you need to Call HP Support .
Try first unplugging printer power cable for ten minutes, if that did not work , call HP, they will send you a patch to fix the error, see below:
Customer Service / Contact HP
Posted on Jan 23, 2009
    Genius:
  • 2,920 Answers
I would say its about time for a new printer.....if its leaving a black line all the way down the side of the page it usually means the black carrier is going bad.
Posted on Jan 21, 2009
    Brigadier General:
  • 5,158 Answers
Take out the toner and give the cartridge a good shaking... put it back in and try it.
Robert
    President:
  • 1,990 Answers
Welcome to Fixya! You need to Clean the Print Head. Take some Alcohol and a Q tip and remove the Print Cartridges. Clean the Electronic Heads under these and then Clean the Contacts on the Cartridges. If this does not work, Let me know!
  • HP Master
  • 13,433 Answers
Perform maintenance on the printer, the hp toolbox that came with the printer. Aling the cartridges, clean the print head and all other options you have there.
  • Ekse Jan 21, 2009
    I'm sorry Is this a Laser printer? What model? is it the model you have indicated above, I completely missed that.
Use a hp deskjet 35200(3500). when unit is printing all lines are blurd and paper gets black streaks all over. The printing is unreadable and smudged.Is there a manner to clean this up?
Streaks:Cleaning interior
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
Feb 06, 2011 | HP Office Equipment & Supplies
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Getting streaks down left margin
I guess you have a problem in your fuser assembly
Mar 12, 2010 | HP LaserJet 1320 Printer
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
Vertical streak near left edge of printouts....only affects black portion of print image
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Apr 11, 2007 | Ricoh CL3000E Laser Printer
HP LaserJet 3015 All-In-One Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
