Question about AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381
5 gallon compressor tries to start then stops
AllTrade Model 480768 5 gallon tries to start then it stops. It was low in oil and added then tried again, but same condition.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
It sounds like the unloader is not working so it's trying to start with to much head pressure. One cause is a bad check valve another is a bad pressure switch. Those are the more common problems.
Posted on Jan 05, 2013
I have a 1999 ford expedition. when I come to a stop, it starts to shake a little.
check the dipstick but I suspect that with 6 quarts ( gallon and a half)in an already filled sump that takes 4 quarts max is trouble in itself
coming to a stop and shaking indicates a vacuum leak or problem injectors
take it to an accredited service center , have the oil level adjusted and have the fault codes read
Feb 26, 2017 | Ford Cars & Trucks
All Trade 5 Gal just humms wont turn on
The start capacitor has gone bad. Needs to be replaced. That's what's inside that bump on the side of the motor.
Mar 25, 2013 | Alltrade 830241 5 Gallons 3 HP Twin Tank...
Where is oil sensor on honda gx160 5.5
The low oil sensor is on the front of the block the wires are attached to ur start stop switch. It has two wires yellow and black on most models. the sensor itself is internal
Dec 11, 2012 | Honda Quincy 17 - Gallon Air Compressor...
6.5hp 80 gallon tank when it gets hot it shouts off
need a little more info. Does it shut off because it tripped the breaker? overload? does it boug down and stop? does it stop when trying to restart? is the compressor get hot enough to change the color of the discharge tube?
Dec 17, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
What would cause load unload sump pressure?
Is this a rotary screw unit? Was it low unloaded sump pressure? If so the most probable cause is the minimum pressure check valve located under the aluminum cap on the seperater tank (oil tank). The check valve piston binds in the housing due to rust, dirt,etc. If you are going to attempt the repair your self I would recommend purchasing rebuild kit before disassembly.
If this problem is with a 2475 unit I would look at the pressure switch. If you are saying the unit starts/stops/starts etc and it is equiped with a low oil level switch the oil level is low. fill it to the oil fill plug threads.
Mar 03, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
Compressor will not run
could be the capacitor, also try looking at the wires around the windings
May 17, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Have 12 gallon / 1HP Craftsman compressor, accidentally ran it while it was low on oil....about half way low. It shut itself off. Then, I added oil and it started up. But now it builds pressure VERY slowly...
Not the motor, but probably the compressor shot. Heat from friction (due to running without oil) probably scored the cylinder walls, which allows air to escape past the piston and rings, making the compressor VERY inefficient. Some compressors have replaceable cylinders... Not sure if the very small ones do or not.
Jun 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381 Logo
142 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
